Converting Trigonometric Ratios to Degree
This discussion focuses on converting trigonometric ratios from radians to degrees, specifically using the example of 0.3333 radians, which approximately equals 19.1 degrees. The conversion formula utilized is based on the relationship that 2π radians equals 360 degrees, allowing for the calculation of degrees from radians by multiplying the radian value by 360/2π. The user questioned a discrepancy with a book's value of 19.47 degrees, which was clarified as an error. This method is applicable in various fields including mathematics, physics, and chemistry.
  • Understanding of radians and degrees
  • Basic knowledge of trigonometric functions
  • Familiarity with the concept of unit conversion
  • Ability to perform basic arithmetic operations
  • Study the unit circle and its significance in trigonometry
  • Learn about the relationship between radians and degrees in more depth
  • Explore trigonometric functions and their applications in physics
  • Practice converting various trigonometric ratios manually
This discussion is beneficial for students learning trigonometry, educators teaching mathematical concepts, and anyone interested in understanding the conversion between radians and degrees for practical applications in science and engineering.
ahmadaming60
Hi! I'm just a beginner i don't know much about trigonometry... can you tell me how to convert the trigonometric ratios to degree.. for example:
o.3333 how did it become 19.47degree ? i saw it in the book... can you tell me how? I know this is simple for you all! i want to solve it without using calculator... is there a formula to solve it manually?
Yes, there is a formula! The formula is simply a ratio. This isn't just used in math, it is used in physics and chemistry all the time to change units of measure (which is the same thing we are doing here).
How many radians are in a circle? ##2 \pi## rad
How many degree are in a circle? ##360^{\circ}##
Therefore, ##2 \pi \text{ rad} = 360^{\circ}##
And so, ##1 = \frac{2 \pi \text{ rad}}{360^{\circ}} = \frac{360^{\circ}}{2 \pi \text{ rad}}##.
So, in your example, you have ##0.3333 \text{ rad}##. Multiply by one so that the radians cancel with radians.
##0.3333 \text{ rad} \cdot 1 = 0.3333 \text{ rad} \cdot \frac{360^{\circ}}{2 \pi \text{ rad}} \approx 19.1^{\circ} ##
I'm not sure how the book got 19.47 degrees, they are off by a bit.
I hope that clears it up!
  • · Replies 49 ·
  • · Replies 30 ·
