Convincing a Flat Earther: Proving the Earth is Spherical
  • Context: Undergrad
  • Thread starter Thread starter jim77
    Earth Flat Spherical
The discussion revolves around methods to convince a flat earther of the Earth's spherical shape. Participants explore various approaches, including mathematical experiments and observational evidence, while addressing the challenges of engaging with individuals who hold strong alternative beliefs.
  • One participant suggests measuring the angle of shadows cast by a stick at two different locations to demonstrate that the sum of the angles will differ if the Earth is spherical.
  • Another participant proposes a video chat with individuals across different time zones to show the varying positions of the sun, implying that this could serve as evidence of a spherical Earth.
  • A different approach involves using a modification of Eratosthenes' method, where participants measure the angle of the sun at local noon to calculate the Earth's circumference based on latitude differences.
  • Some participants express skepticism about the effectiveness of these methods, questioning whether a flat earther would accept any evidence presented.
  • Concerns are raised about the potential for alternative explanations for observed phenomena, such as the angles of shadows or visibility of distant objects, which could be interpreted differently by flat earthers.
  • Humor is introduced in the discussion, with one participant suggesting that engaging with conspiracy theories could lead to absurd conclusions.
Participants generally do not reach a consensus on the effectiveness of the proposed methods to convince a flat earther. Multiple competing views and skepticism about the acceptance of evidence remain present throughout the discussion.
Participants highlight the limitations of individual pieces of evidence, suggesting that a comprehensive theory is necessary to explain all observations. There is also mention of the potential for clever geometry to replicate ancient measurements on a flat surface, indicating a need for careful consideration of assumptions in the arguments presented.
This discussion may be of interest to individuals exploring methods of scientific persuasion, those engaged in debates about the shape of the Earth, or anyone interested in the dynamics of discussions involving strongly held beliefs.
jim77
Because I must be a masochist I would like to know how I could convince a flat earther that the Earth is a sphere. The way I've chosen to do it is the following. I live in Honolulu and the person I am trying to convince lives in south america. At an agreed upon time we both take a 50 cm stick outside and measure the angle of the shadow and its offset from magnetic north. Knowing the position of the sun at that time will give us both right triangles so we add 90 degrees to the angle we measured and subtract that from 180. then we'll add both of the remainders together. His measured angle plus mine plus the sum of the two remainders will add up to 180 if the Earth is flat and something other if the world is round. Do I have this correct? Is there any advice you can give me to make it as simple as possible with as small a possibility for error as can be? It seems like with the internet this should not be an issue so I am hoping that this simple math experiment will show them that they are mistaken. (Unlesss of course you astronomers have actually been tools of the underground global authority and forbidden to tell us the truth that the sun is actually only 35 miles up like they say, You arent part of a global conspiracy here are you? I didnt think so but thought I'd ask :)
Astronomy news on Phys.org
This is my favorite proof:
Mine is this:
Make a video chat call to, say, three people on different continents, some in the daytime, others at nighttime, others at e.g. sunset. Ask them to show the sky.
Of course, a sufficiently stubborn insanity can refuse to be convinced by anything.
jim77 said:
At an agreed upon time...
Isn't that enough evidence on its own?
...we both take a 50 cm stick outside and measure the angle of the shadow and its offset from magnetic north. Knowing the position of the sun at that time will give us both [different] right triangles...
This too.
I really don't see what you are trying to do with that math (it isn't clear to me which angles you are using), but honestly, is he really going to accept anything? If he already knows about time zones (the first quote), isn't that enough evidence that the Earth must at least be a cylinder?
Or start a chat with him just before sunset and ask him what it looks like from where he lives.
Or when you put the stakes in the ground and measure the angles are different in both axes, just knowing that they are different tells you the Earth is curved in both directions, doesn't it?
You could use a modification of Eratosthenes' method to calculate the Earth's circumference:
https://www.windows2universe.org/citizen_science/myw/w2u_eratosthenes_calc_earth_size.html
Each of you measure the angle of the sun at local noon. Subtract the two angles and you should get the difference between your latitudes. If you want to take it further you can measure on a map how far south he is from you and multiple by 360/that angle.
Why would you even waste your time arguing with these kind of people? :nb)
Brilliant! thanks for the responses. Especially the cat one.
Not necessarily, If you put two stakes on a flat surface and move the light itself around, you will get different angles. Science isn't about a individual pieces of evidence that may have multiple solutions, it's about coming up with a theory that explains ALL evidence. You could easily replicate almost all types of ancient measurement with a flat plane and clever geometry. It's things like the fact that you can't see the bottom few tens of feet of Chicago from Canada, or simply that we've been high enough to see the Earth as a ball that can't be explained by anything other than a great science conspiracy.
I think it's best to simply one-up the conspiracy nut with something even more ludicrous:
"The sun's shadows can easily be created on a flat plane"
"Pffft, you believe in the sun?"
Not if the light is far away and the angles are measured at the same time.
  • · Replies 25 ·
  • · Replies 67 ·
16K
  • · Replies 58 ·
