Coordinate System-Spring Vertical
This discussion revolves around the application of coordinate systems in the context of a vertical spring and the forces acting on a mass attached to it. Participants are examining the conventions used in the Princeton Review regarding the directionality of forces and displacements.
  • Participants are questioning the choice of coordinate system used in the Princeton Review, particularly whether the displacement of the spring should be considered positive or negative. There is a discussion about the implications of defining upward as positive versus downward, and how this affects the net force equation.
Some participants have provided insights into the reasoning behind the negative sign in Hooke's Law and how it relates to the direction of motion. Others are seeking clarification on the coordinate system used and whether it aligns with standard conventions. There is an ongoing exploration of different interpretations and the potential need for visual aids to enhance understanding.
There is mention of a lack of diagrams and the potential for confusion stemming from different conventions in defining positive and negative directions. Participants are also expressing uncertainty about the clarity of the material presented in the Princeton Review.
samtouchdown
Coordinate System--Spring Vertical
Hi! This is a question on the use of a coordinate system.
In the princeton review, I don't understand the coordinate system they are using it; it doesn't make sense. That is, for a vertical spring, the net force on the mass is kx-mg. But, shouldn't it be mg-kx? The component of spring vertical is -kx, not +kx. What type of coordinate system would have +kx? This may be a trivial matter, but any help to ease my slight confusion would help! Thanks.
If sense is used consistently, the displacement should be measured in the same direction as the force. You don't supply a diagram. The only way I can imagine the displacement and force would be positive at the same time is if the spring is considered part of the mass, and the displacement is that of the other end of the spring. That would be unusual.
Alternatively, and again unusually, displacement is being measured in one sense and force in the opposite one.
Haruspex is correct in his response. The idea is that the force given by Hooke's Law for Springs counters the motion. This is the reason for the negative sign. So here, the object is moving downward. Let us choose the downward direction for [itex]+\hat{i}[/itex]. Then, [itex]mg[/itex] is "positive", and the force that counters it is the one given by Hooke's Law for Springs, [itex]-kx[/itex]. So the net force can be found using Newton's Second Law: [itex]F_{net} = F_{g} + F_{s} = mg+(-kx)[/itex] which can be simplified down to [itex]mg-kx[/itex], as you asked for. Just realize that it counters the motion. It moves downward, so Hooke's Law tells you that [itex]F_{spring}[/itex] counteracts this, and thus carries the negative sign. By convention, Princeton Review chooses down [itex](\downarrow)[/itex] to be the direction for [itex]+\hat{i}[/itex]. They mention this somewhere in the early stages of the book. Hope this helps!
But they do kx-mg in the princeton review.
Oh I see what you're saying. So they take up to be positive then, that's all.
Chirag B: I don't understand how they take it to be upward. Fspring=-kx always.
In this case, they define up to be positive and down to be negative. Suppose, the spring is stretched 2 m, then the displacement vector is obviously=-2i. So, then this "kx", which they use, would yield -2k, still in het direction of the stretch, which is obviously wrong.
I'm not sure I understand what you're saying Princeton Review is doing. Can you possibly scan a picture so others understand how this works?
Here. Please tell me if the image
is of bad quality.
is of bad quality.
I can't read it. Needs about nine times the pixels.
  • · Replies 24 ·
