Are Coordinates on a Manifold Really Functions from R^n to R?
  • Context: Undergrad
  • Thread starter Thread starter kiuhnm
    Manifold Manifolds
The discussion centers on the nature of coordinates on an n-dimensional smooth manifold M and their relationship with the chart (U, φ) mapping to ℝⁿ. Participants debate whether coordinates x¹, ..., xⁿ should be viewed as functions from U to ℝ or from ℝⁿ to ℝ. The consensus suggests that while φ(p) = (x¹(φ(p)), ..., xⁿ(φ(p))) is accurate, it is also an abuse of notation to express coordinates as functions of points on the manifold. The key takeaway is that coordinates are local representations that depend on the chart and the image point in ℝⁿ, emphasizing the importance of context in their definition.
  • Understanding of smooth manifolds and their properties
  • Familiarity with coordinate charts and homeomorphisms
  • Knowledge of Euclidean space and Cartesian products
  • Basic concepts of calculus on manifolds
  • Study the definition and properties of smooth manifolds
  • Learn about coordinate transformations and their implications in differential geometry
  • Explore the concept of local versus global coordinates on manifolds
  • Investigate the role of charts in defining structures on manifolds
Mathematicians, particularly those specializing in differential geometry, students of advanced calculus, and anyone interested in the foundational concepts of manifolds and their coordinate systems.
kiuhnm
Let ##M## be an ##n##-dimensional (smooth) manifold and ##(U,\phi)## a chart for it. Then ##\phi## is a function from an open of ##M## to an open of ##\mathbb{R}^n##. The book I'm reading claims that coordinates, say, ##x^1,\ldots,x^n## are not really functions from ##U## to ##\mathbb{R}##, but from ##\mathbb{R}^n## to ##\mathbb{R}##. In other words, we should write $$
\phi(p) = (x^1(\phi(p)), \ldots, x^n(\phi(p)))
$$ instead of $$
\phi(p) = (x^1(p), \ldots, x^n(p)).
$$ That doesn't sound right to me. ##\mathbb{R}^n = \mathbb{R} \times \cdots \times \mathbb{R}##, which means that an element of ##\mathbb{R}^n## is already an ##n##-tuple, so why should we define an extra coordinate system on it? If we want a different coordinate system we just pick a different chart and not the same chart with a different coordinate system for ##\mathbb{R}^n##.
Do you agree or am I missing something?
$$ instead of $$
We do not have coordinates on ##M##, which is why we use those of the chart, which are coordinates at ##\phi(p)##. A coordinate ##x^i(p)## is simply not defined, resp. will be defined as ##y^i(p) := \phi^{-1}(x^i(\phi(p))##. So the question is: Where are we, on the manifold or in the Euclidean space of the chart?
An element of ##\mathbb{R}^n## has the form ##(x_1,\ldots,x_n)## by definition, so we must have ##\phi(p) = (\phi_1(p),\ldots,\phi_n(p))##. Why should we define a coordinate system for ##\mathbb{R}^n## when ##\mathbb{R}^n## is already a cartesian product? I would agree with you if we were talking about the vector space ##\mathbf{R}^n##, but we're not.
I don't know which context we have here, but e.g. if the ##\mathbb{R}^n## is the tangent space, then the coordinates are functions themselves. This is also generally true: if we vary ##\phi(p)## we get different coordinates. And they do depend on the image point on the chart, and not on the one of the manifold, if we write it correctly.
We're not talking about tangent spaces here. The manifold could be non-smooth. We're talking about the charts ##(U,\phi)## where ##\phi:U\to\mathbb{R}^n## is an homeomorphism. The point is whether we need to introduce coordinates ##x_1,\ldots,x_n## explicitly or if ##x_i## is just ##\phi_i##. I'm saying it's the latter, whereas the author of the book and you (if I understand you correctly) say it's the former. My argument is that ##\mathbb{R}^n## is a cartesian product so we don't need to introduce a basis and coordinates to indicate points in ##\mathbb{R}^n##. The points can already be indicated through tuples thanks to ##\mathbb{R}^n## being a cartesian product, so I don't think that identifying ##\phi_i## with ##x_i## is an abuse.
##\phi = (\phi_i)\, : \, M \supseteq U \longrightarrow \mathbb{R}^n## and ##(x_i) \, : \, \mathbb{R}^n \longrightarrow \mathbb{R}^n\,.## Since ##p \notin \mathbb{R}^n\,,## ##x_i(p)## is a sloppy notation.
I agree with @kiuhnm here. In my experience, x^i means the ith component of \phi, so is a function U\to\mathbb{R}. Can you show exactly what your textbook says?
I don't understand, either. If ##\phi## is a function from ##U## to ##R^n##, and the coordinates are frunctions from ##R^n## to ##R##, why not just say that coordinates are a function from ##U## to ##R##?
What I do understand that a coordinate transformation is a function from ##R^n## to ##R^n##. So the transformations no longer involve the manifold.
Whether something is an abuse or not depends on the definitions you choose. You decided to define the ##x_i## the way you did, which makes my notation an abuse. But the point is this: what do you gain by using your definition? Or in other words, what do I lose by not using it?
This would be my understanding also (as long as the chart is clear from the context).
It depends on whether you want to distinguish the Euclidean coordinates from their pullbacks to the manifold. As I mentioned earlier: it is all a matter of where you are. If the ##x_i## are Euclidean coordinates, then they do not apply to points of the manifold, but on their image under the chart instead. If they are meant to be the local coordinates on the manifold, then they apply to points of it, but aren't Cartesian anymore. If you prefer a mishmash then you can switch back and forth and risk the loss of rigor. You seem to identify base points with points anywhere in the fiber, a bit too arbitrary if you ask me, because you reduce notation to a single section.
It says:
--- starts ---
Let ##(U,\phi)## be a coordinate chart with ##p \in U## and suppose that ##\phi(p)=q##. If ##x^1,\ldots,x^n## are the standard coordinate functions on ##\mathbb{R}^n## then ##q## has coordinates ##(x^1(q),\ldots,x^n(q))##. Thus we can write $$
\phi(p) = (x^1(q),\ldots,x^n(q)).
$$ It is a convenient abuse of notation to view the ##x^i## as coordinate functions on ##U## instead of ##\phi(U)## and to write $$
\phi(p) = (x^1(p),\ldots,x^n(p)).
$$ As ##U## generally does not live in Euclidean space, the second expression above makes no sense unless it is interpreted to mean the first one. (Of course, if ##U## is a subset of Euclidean space then ##\phi## is just the identity map, so the second expression makes perfect sense; this is the justification for the convention.)
--- ends ---
While it's true that the ##(x^i)## can't be global coordinates on ##U## if ##U## is not Euclidean, they can certainly be local coordinates on ##U##. Wasn't that the whole point of using the charts?
kiuhnm said:
While it's true that the (xi)(xi)(x^i) can't be global coordinates on ##U## if ##U## is not Euclidean, they can certainly be local coordinates on ##U##. Wasn't that the whole point of using the charts?
Yes, as long as you are talking about a certain section such as tangent spaces, which is why I asked.
It works in what was the whole point of using the charts but terminology developed and was generalized.
Maybe I'm starting to see the problem with my definition: the coordinates would just be a local parametrization of the curve but maybe I'd lack enough structure to do regular calculus over them. The cleanest way is to define ##\phi## from ##M## to ##\mathbb{R}^n## and then the coordinates on ##\mathbb{R}^n## itself. That way, it's clear we can do regular calculus with them. I don't know anything about fibers and such so please try to keep the discussion a little less formal for my sake :)
Right, An n-tuple of functions might not be a coordinate chart.
I'm still not completely sure. We assumed that ##(U, \phi)## is a coordinate chart from the start. Let's say ##\phi## goes from the manifold ##M## to ##\mathbb{R}^n## and we also have some coordinates ##x^i:\mathbb{R}^n\to\mathbb{R}##. Then let's define ##\phi^i = x^i\circ\phi##. Would ##(U, (\phi^1,\ldots,\phi^n))## still be a valid chart? I suspect we threw away some structure from a strictly formal and maybe overly pedantic point of view but in practice we know it's still there and so we don't care.
Yes, it would be a chart. ##(U, (\phi^1,\ldots,\phi^n))## is the same as##(U, \phi)##. Otherwise put, ##(\phi^1,\ldots,\phi^n))## is the same mapping of ##U## into ##R^{n}## as ##\phi##.
All the book is pointing out is that the coordinates functions are compositions of ##\phi## with the coordinate functions on ##R^{n}##. If one had different coordinates on ##R^{n}## there would be different coordinate functions on ##U##. If one had a different chart on ##U## the coordinate functions on ##U## would be different.
I thought you were saying that if you just had an n-tuple of functions on ##U## that is would not necessarily make a chart. That is true.
In my head I was identifying ##x^i## with ##\phi^i## and so the ##x^i## were local coordinates directly on ##U##.
In the meantime I'd like to thank you all for your patience!
  • · Replies 36 ·
  • · Replies 36 ·
  • · Replies 0 ·
  • · Replies 20 ·
