D H said:
There is an centrifugal force from the perspective of an Earth-fixed frame.
What I agree with of course is that the same thing can be calculated in different ways.
The thing is: I'd like to argue against stating things metaphorically when there is no need to do so.
I think it's unpractical to use a phrasing such as "there is a centrifugal force from the perspective of [...]". It is more straightforward to say for instance: "When the motion is mapped in a coordinate system that is co-rotating with the Earth then a centrifugal term is added to the equation of motion."
That is what you actually do when using a co-rotating frame: you add the appropriate terms to the equation of motion. No physicist actually thinks that the centrifugal term in the equation represents a physically real centrifugal force. Adding the centrifugal term represents the fact that a co-rotating coordinate system is used.
For explanation of physics the following elements are admissible:
- The four fundamental interactions of nature (Gravitation, Electromagnetism, strong nuclear force, weak nuclear force)
- Inertia
If we consider only macroscopic physics then the list is of course shorter:
- The two long range fundamental interactions of nature: Gravitation, Electromagnetism
- Inertia.
Example involving EM and inertia:
An electric car that is designed for regenerative braking. When the car's driver switches to braking the energy flow in the drive-train reverses, and the batteries are recharged.
Regenerative braking works because of the existence of
inertia. A force is required to reduce the relative velocity between the car and the road to zero. During the braking kinetic energy is converted to chemical potential energy in the batteries.
In the case of the electric car with regenerative braking you can opt to map the motion with respect to the road, or you can map the motion in a coordinate system that is co-moving with the initial velocity of the car. Either way it's the same physics taking place, and it's actually important to emphasize the physics taking place is
independent of the choice of coordinate system.
Cleonis
