Correcting Solutions for Euler's Equation with Kronecker Delta Function
  • Thread starter Thread starter Precursor
    Euler's equation
The discussion focuses on solving Euler's equation given by r^2 B_n'' + r B_n' - n^2 B_n = 3 δ_{n1} r^2, where δ is the Kronecker delta function. The solution is established as B_n(r) = β_n r^n + δ_{n1} r^2 for n ≥ 1, with β_n being a free coefficient. The case for n=1 is treated separately due to the right side being 3r^2, while for other values of n, the right side equals zero. It is concluded that β_1 must equal zero to satisfy the boundary conditions, indicating that the problem statement is imprecise.
  • Understanding of differential equations, specifically Euler's equations
  • Familiarity with the Kronecker delta function and its applications
  • Knowledge of boundary conditions in mathematical solutions
  • Experience with trial functions in solving differential equations
  • Study the properties of the Kronecker delta function in mathematical contexts
  • Learn about boundary value problems and their significance in differential equations
  • Explore the method of trial functions for solving differential equations
  • Investigate the implications of coefficients in differential equations and their physical interpretations
Mathematicians, physicists, and engineers dealing with differential equations, particularly those interested in boundary value problems and the application of special functions like the Kronecker delta.
Precursor
How do I solve the following Euler's equation:
r^2 B_n'' + r B_n' - n^2 B_n = 3 \delta_{n1} r^2
Such that the solution is:
B_n(r) = \beta_n r^n + \delta_{n1}r^2, \forall n \ge 1
where βn is a free coefficient, δ is the Kronecker delta function, and the solutions unbounded at r=0 are discarded.
where \beta_{n} is a free coefficient, \delta is the Kronecker delta function, and the solutions unbounded at r = 0 are discarded.
You try to solve the differential equation for different values of n. n=1 is obviously different from all other n. The trick for an equation in this form is to use a trial function of the form ##B_n(r)=Cr^k## and solve for k.
Is the \delta_{n1}r^2 obtained in the solution by linearity? And why is the coefficient '3' not in front?
I'm not sure what you are asking. The case n=1 is different from the other values of n because then the right side is 3r^2. If n is not 1 then the right side is 0. That's what the Kronecker delta does. They are two different cases. Solve them separately.
I've followed your steps, but when I'm solving the case for n = 1, I get B_{1} = \beta_{1}r + r^{2}. Shouldn't it only be r^{2}?
Yes, it should. You have to put ##\beta_{1}=0## in that case. The problem statement is sloppy.
  • · Replies 16 ·
