Proving the Relationship between Cosine and Inverse Sine Functions
  • Context: MHB
  • Thread starter Thread starter Wild ownz al
The relationship between cosine and inverse sine functions is established through two proofs. First, it is proven that cos(sin-1x) = √(1-x2) by applying the identity cos2θ + sin2θ = 1. Second, the equation cos-1a + cos-1b = cos-1(ab - √(1-a2)√(1-b2)) is derived using the cosine addition formula. Both proofs utilize the properties of inverse functions and the defined ranges of the sine and cosine functions.
  • Understanding of trigonometric identities, specifically cos2θ + sin2θ = 1
  • Familiarity with inverse trigonometric functions, particularly sin-1x and cos-1x
  • Knowledge of the ranges of inverse sine and cosine functions
  • Basic algebraic manipulation skills
  • Study the derivation of trigonometric identities in depth
  • Explore the properties and applications of inverse trigonometric functions
  • Learn about the cosine addition formula and its implications
  • Practice solving problems involving inverse functions and their relationships
Mathematicians, students studying trigonometry, educators teaching trigonometric concepts, and anyone interested in understanding the relationships between trigonometric and inverse functions.
Wild ownz al
Prove:
a) cos(sin-1x) = √(1-x2)
b) cos-1a+cos-1​b = cos-1(ab-√(1-a2)√(1-b2) (edited)
(VERY HARD)
Hi Wild ownz al.
Try using the identity $\cos^2\theta+\sin^2\theta=1$.
(a) We have $\sin^2(\sin^{-1}x)=x^2$ and so
$$\cos^2(\sin^{-1}x)\ =\ 1-\sin^2(\sin^{-1}x)\ =\ 1-x^2$$
$\implies\ \cos(\sin^{-1}x)\ =\ \sqrt{1-x^2}$
taking the positive square root because the range of $\sin^{-1}x$ (for $-1\le x\le1$) is $\displaystyle\left[-\frac{\pi}2,\,\frac{\pi}2\right]$ on which the cos function takes non-negative values.
(b) Check your equation. There should be an equals (“=”) sign, which is missing.
Olinguito said:
Hi Wild ownz al.
Hey Olinguito,
I'm a bit confused as to your steps...did you manipulate the left hand side or the right hand side? Also could you start from the given equation? I corrected part b). Thanks.
Wild ownz al said:
Prove:
(VERY HARD)
(b) let $\theta = \cos^{-1}{a} \implies \cos{\theta} = a \text{ and } \sin{\theta} = \sqrt{1-a^2}$,
also, let $\phi = \cos^{-1}{b} \implies \cos{\phi} = b \text{ and } \sin{\phi} = \sqrt{1-b^2}$$\cos(\theta + \phi) = \cos{\theta}\cos{\phi} - \sin{\theta}\sin{\phi}$
$\cos(\theta + \phi) = ab - \sqrt{1-a^2} \cdot \sqrt{1-b^2}$
$\cos^{-1}\left[\cos(\theta + \phi)\right] = \cos^{-1}\left[ab - \sqrt{1-a^2} \cdot \sqrt{1-b^2}\right]$
$\theta + \phi = \cos^{-1}\left[ab - \sqrt{1-a^2} \cdot \sqrt{1-b^2}\right]$
$\cos^{-1}{a} + \cos^{-1}{b} = \cos^{-1}\left[ab - \sqrt{1-a^2} \cdot \sqrt{1-b^2}\right]$
Note that the $\sin$ and $\sin^{-1}$ are inverse functions.
For example, $\sin^{-1}\dfrac12=\dfrac{\pi}6$ and $\sin\dfrac{\pi}6=\dfrac12$; that is to say, $\sin\left(\sin^{-1}\dfrac12\right)=\dfrac12$.
Thus we have $\sin(\sin^{-1}x)=x$ for $-1\le x\le1$.
The rest of my post should be straightforward.
  • · Replies 22 ·
