Could one use a capacitor to enhance a capacitive stylus?
  • Thread starter Thread starter lostminty
    Capacitor
This discussion centers on the feasibility of using a capacitor to enhance the functionality of a capacitive stylus for touchscreens. Capacitive touchscreens operate by forming a capacitor when a conductive object, like a finger or a specialized stylus, touches the screen, allowing the controller to detect the touch location. The conversation highlights the limitations of current capacitive styluses, which require a conductive tip to function effectively. One participant proposes the idea of using a monopole capacitor to create a finer point for stylus interaction, although there is uncertainty about its practical application.
  • Understanding of capacitive sensing technology
  • Knowledge of capacitive touchscreen mechanics
  • Familiarity with stylus design and functionality
  • Basic principles of electrostatics and capacitance
  • Research the design and functionality of capacitive styluses
  • Explore the principles of monopole capacitors and their applications
  • Investigate the limitations and calibration processes of capacitive touchscreens
  • Learn about the differences between capacitive and resistive touchscreen technologies
Electronics enthusiasts, product designers, and developers interested in enhancing touchscreen technology and stylus functionality.
lostminty
I don't well understand capacitance and its use in touch screens. Just had a crazy idea that you could involve a charged capacitor to enhance the accuracy of a stylus.
capacitive touchscreens don't use a stylus they require finger touch
have a look at this wiki page ... scroll down to the capacitive section...
In this basic technology, only one side of the insulator is coated with a conductive layer. A small voltage is applied to the layer, resulting in a uniform electrostatic field. When a conductor, such as a human finger, touches the uncoated surface, a capacitor is dynamically formed. The sensor's controller can determine the location of the touch indirectly from the change in the capacitance as measured from the four corners of the panel. As it has no moving parts, it is moderately durable but has limited resolution, is prone to false signals from parasitic capacitive coupling, and needs calibration during manufacture. It is therefore most often used in simple applications such as industrial controls and kiosks.
if the touchscreen responds to stylus or finger then it will be a resistive touchscreen
Dave
What I'd like to know is which direction is the field that is measured?
into or out of the plane
its measured across/along the plane
ie. between the place of touch and the 4 corners of the touch panel
Dave
You can absolutely use a stylus on a capacitive screen. I am using one as I write this on my iPad, which is capacitive. You need a special capacitive stylus, though. It is conductive and typically has a rubber-like tip.
yeah a special one , not some random pointer of some sort
that's what makes them so incompatible for easy everyday use
Dave
What I want to do is have a mono pole capacitor so that the tip size can be reduced. I'm probably concepting it wrong though to think that would work. Essentially it would be static electricity on a stick.
  • · Replies 30 ·
  • · Replies 17 ·
