Capacitor plate current skin effect
30 replies · 5K views · last reply
Baluncore said:
A small positive patch, close to a large negative plate, will draw electrons out of the large plate surface. Since C = Q / V, the charge drawn out will be Q = C⋅V ; That is, for a fixed voltage, charge is proportional to the capacitance.
If the positive patch is then moved around on the plate, the mound of electrons on the plate surface will be dragged about, following the moving patch. A momentary surface current of electrons will flow, where the edge of the small moving patch, covers or uncovers the larger plate.
Well , is the surface current that you talk about parallel to the plate surface or perpendicular? Because @Ivan Nikiforov claims and shows even with an animation that there is only perpendicular movement of electrons due to the change in plate location. You left out that distinction but that is an important one, which causes some misunderstanding to me.
