How Do I Calculate Temperature in a Thermodynamics Problem?
The discussion focuses on calculating the heat required to raise the temperature of milk in a thermodynamics problem. The specific heat capacity (SHC) of milk is identified as 3.9E3 J/kg·K, and the correct mass of the milk is determined to be 0.187 kg. The total heat required to increase the temperature of the milk by 1 Kelvin is calculated to be 729.3 J. Additionally, the heat capacity of the combined milk and bottle system is noted as 770 J/K, emphasizing the distinction between heat capacity and specific heat capacity.
  • Understanding of specific heat capacity and heat capacity concepts
  • Knowledge of mass and density calculations
  • Familiarity with thermodynamic equations for heat transfer
  • Ability to interpret data from thermodynamic tables
  • Research the differences between specific heat capacity and heat capacity
  • Learn how to use thermodynamic tables for various substances
  • Explore calculations involving heat transfer in mixed systems
  • Study the principles of calorimetry in thermodynamics
Students and professionals in physics or engineering, particularly those studying thermodynamics, heat transfer, and calorimetry. This discussion is beneficial for anyone needing to calculate heat changes in systems involving liquids and solids.
Zeynaz
A baby bottle contains 180mL milk. The heat capacity of the bottle and the milk is 770 J/K. The density of the milk is 1.04 kg/dm^3
a) calculate the heat capacity of the bottle
Q=C*dT
Q=cm*dT
Density =mass/Volume
So, I converted the V (milk) to m3 and found 1.8E-4 m3 and i already know the density so i found the mass of the milk in the bottle.
Mmilk= 1.9E-7 kg
Normally i would try to connect it with the formulas above but i don't know temperature. I am not sure how i can connect the dots.
Can someone help me about this?
Thanks!
Probably you can assume that the specific heat capacity for the milk is the same as for water.
How many Joules of heat must be added to the milk alone in order to raise the temperature of the milk by 1 Kelvin?
Also, check your calculation of the milk's mass.
EDIT: I don't think you should assume that the specific heat capacity of the milk is the same as for water. Were you given a value for milk, maybe in a table?
Yes you are right there is a table where i can find the density and specific heat capacity of all substances. So in this case the SHC of milk is 3.9E3.
And i think i found the right mass for the milk which is 0.187kg. The answer should be 40J/K but i don't know how to get there
So i know the combines SHC of milk and the bottle. I know the SHC of the milk. Am i just supposed take it as an average and say: SHC bottle+milk= (SCHmilk +SHCbottle)/2 ?
No, that won't work. Did you try to calculate the amount of heat required to increase the temperature of just the milk by 1 Kelvin?
How much heat would be required to increase the total milk-and-bottle system by 1 Kelvin?
For Q-milk= m,milk * c = 729.3 J
For Q Bottle-Milk= (m-milk+m-bottle)*770
But i don't know mass of the bottle.
Meanwhile, i also tried to find the mass of the bottle first by equating Q milk with Q bottle and i got 0.760kg and tried to work my way but it didnt really work.
Another way,
When i write: Qmilk-bottle = Q-bottle + Q milk and apply mass of the bottle, it doesn't give me the right answer and also i don't know Q b-m
OK. This is the heat that must be added to the milk alone in order to increase its temperature by 1 K.
Note that the value of 770 J/K is not the specific heat capacity, ##c##, of the system. Rather, it is the heat capacity, ##C##, of the system. It is important to distinguish these. Can you express in words the meaning of the quantity 770 J/K?
There is no reason to expect that Q for the milk will be the same as Q for the bottle.
That to increase 1 Kelvin of bottle-milk system we need 770 joules so in that case, technically i can take 770 as Q for bottle-milk system right?
Yes. You also know the heat required to raise the temperature of just the milk by 1 K. Can you deduce how much heat is required to raise the temperature of just the bottle by 1 K?
Thank you for your help I figured it out!
OK, good work.
