Coulomb's Law and charged particles
47 replies · 17K views · last reply
Well I thought because,
Q1 = -Q2 = 100nC, then Q2 will just be -100nC
and
Q3 = -Q4 = 200nC, then Q4 will equal -200nC
Thanks for your help
I also have another question I am not too sure about.
(Click on the attachment for question and diagram)
In this next question I am guessing because the length between particle 1 and 2 is 9.00cm that particle 3 will have to be located above the two points giving an equilaterial triangle.
From this we know all the sides will be the same length of 9.00cm with an angle of 60 degrees. However, there is no solid value given for the charge on particle 1 and 2.
Since
Q1 has a charge of +Q
Q2 has a charge of +4.00Q
So does this mean that the above forumula has to be arranged somehow,
for F3,1 and F3,2 ?
learningphysics said:
what is the direction of the force that 2 exerts on 3? just generally.. don't use numbers... is it to the left or to the right? is it upwards or downwards?
The force that 2 exerts on 3 would be going downwards torwards the left?
Q2 and Q3 have opposite signs right? So they will attract... so the force on 3 due to 2 is upwards and to the right.
Ok I understand that, so that makes the answer possitve.
Can't be a triangle because. The 4.00q force only exerts a horizontal force on the q charge. Now placing the 3rd charge above or below the x-axis means that the net force on the q charge will have a nonzero y-component. The same thing with the net force on the 4.00q charge.
So the third charge needs to be placed on the x-axis.
you shouldn't be multiplying by cos45 here... the force between 1 and 3 is vertical... so there is no horizontal component.
Oh yeah that's right.
It would be by 90 degrees because its horizontal,
which means cos 90 = 0 and sin 90 = 1
Thanks
Sorry I have completed the first question,
does this look about right?
X component = -25 x 10-3 i N
y component = 46.48 x 10-3 j N
Net force = 39.18 x10-3 i j N
Are the units right? Should have a dash above the top of i and j?
I'm not getting those...
for the y-component I get -46.5*10^-3
For the x-component it appears you got the x-component of the force of 2 on 3 (but which should be +25*10^-3 not -25*10^-3)... but forgot to add the force of 4 on 3 which is also in the x-direction...
I see so I got the same answers, but mixed up the signs you say?
Which means that the total componets added together (Net Force) is wrong and should be a minus answer.
Therefore
Net Force = - 21.5 x10^3
No, you're missing the force of 4 on 3. please show your calculations in detail... where does the force exerted by 4 on 3 come into your calculations?
Well from the calculations it would make sense to add in a third part into the formula.
Something like this ?
[tex] \sum{\vec{F}_{3_{x}}} = {\left(\frac{{k_{e}}{|q_{3}|}{|q_{1}|}}{{{r}_{31}}^{2}}\right)}{cos{\theta_{31}}}{\hat{i}} + {\left(\frac{{k_{e}}{|q_{3}|}{|q_{2}|}}{{{r}_{32}}^{2}}\right)}{cos{\theta_{32}}}{\hat{i}} + {\left(\frac{{k_{e}}{|q_{3}|}{|q_{4}|}}{{{r}_{34}^{2}}\right)}{cos{\theta_{34}}}{\hat{i}}<br /> [/tex]
[tex] \sum{\vec{F}_{3_{y}}} = {\left(\frac{{k_{e}}{|q_{3}|}{|q_{1}|}}{{{r}_{31}}^{2}}\right)}{sin{\theta_{31}}}{\hat{j}} + {\left(\frac{{k_{e}}{|q_{3}|}{|q_{2}|}}{{{r}_{32}}^{2}}\right)}{sin{\theta_{32}}}{\hat{j}} + {\left(\frac{{k_{e}}{|q_{3}|}{|q_{4}|}}{{{r}_{34}^{2}}\right)} {sin{\theta_{34}}}{\hat{j}} <br /> [/tex]
The answer is different since I did the Q4 and Q3.
It must be the signs.
F3x = (8.99 x10^9) x (200 x 10^-9) x (100 x 10^-9) / 0.05^2 x cos 90 i
+ (8.99 x10^9) x (200 x 10^-9) x ( -100 x 10^-9) / 0.0707^2 x cos 45 i
+ (8.99 x10^9) x (200 x 10^-9) x ( -200 x 10^-9) / 0.05^2 x cos 90 i
= 0 + -0.025 + 0 = -0.025
F3y = (8.99 x10^9) x (200 x 10^-9) x (100 x 10^-9) / 0.05^2 x sin 90 j
+ (8.99 x10^9) x (200 x 10^-9) x ( -100 x 10^-9) / 0.0707^2 x sin 45 j
+ (8.99 x10^9) x (200 x 10^-9) x ( -200 x 10^-9) / 0.05^2 x sin 90 j
= 71.92 + -25.44 x 10^-3 + - 143.84 x 10^-3 = 71.75
F3 = ( (-25 x10-3)^2 + (71.75)^2 ) Square Root
= (5148.06) Square Root
= 71.75
The angle between charge 3 and charge 4 is not 90... it is 0...
also, please be careful about signs... like I said before, get the magnitudes first, and then find out the sign separately by analyzing the situation... don't simply rely on the numbers to give you the right signs...
What is the direction of the charge number 2 exerts on number 3? don't use the numbers... just using the signs of the charges and the geometry you should be able to figure out the direction... is it upwards downwards to the left or to the right?
The direction of the charge that number 2 exerts on 3 will be downwards torwards the left because charge 3 is positive and charge 2 is negative. ?
The answers I get now from replacing 90 with 0 are,
F3x = 0 + - 0.025 + -143.84 x10^-3
so does this mean that -0.025 will become a +
Also for the direction of the charge that number 4 exerts on 3 will also be torwards the left because charge 3 is positive and charge 4 is negative. ?
This means that for, (when changing sin 90 to sin0)
F3y = 71.92 + -25.44 x 10^-3 + 0
-25.44 x 10^-3, Q2 on Q3 will stay negative.
Would that be it?
charge 2 is attracting charge 3 since they are the opposite sign... if charge 3 is on the bottom left and charge 2 is on the top right... the force is upwards and to the right.
charge 1 repels charge 3 since they are the same sign... hence the force that 1 exerts on 3 is downwards...
charge 4 attracts charge 3 since they are the opposite sign... hence the force that 4 exerts on 3 is to the right.
The x-component of the force of 1 on 3 is:
The y-component of the force of 1 on 3 is:
-kq1q3/r^2 = 9*10^9(100*10^-9)(200*10^-9)/0.05^2 = -0.072N
So the force of 1 on 3 is: [tex]-0.072N\vec{j}[/tex]
The x-component of the force of 2 on 3 is:
kq2q3/r^2*cos(45) = 9*10^9(100^-9)(200*10^-9)/0.0707^2cos(45) = 0.02546N
The y-component of the force of 2 on 3 is also: 0.02546N
So the force of 2 on 3 is: [tex]0.02546N\vec{i} + 0.02546N\vec{j}[/tex]
The x-component of the force of 4 on 3 is: kq4q3/r^2 = 9*10^9(200*10^-9)(200*10^-9)/0.05^2 = 0.144N
The y-component of 4 on 3 is 0.
So the force of 4 on 3 is: [tex]0.144N\vec{i}[/tex]
So the 3 forces are:
adding up the 3 forces gives the net force on 3:
[tex]0.16946N\vec{i} -0.04654\vec{j}[/tex]
Thanks very much for your help!
I think I fully understand that question now
and have now managed to get the same answers.
Thanks
Thanks
cool! no prob! :smile: glad you got the same answers, because I was making some mistakes, so I was a little worried that I might have messed up the answers. But I think everything's right now.
