Coulomb's law and related problem
  • Thread starter Thread starter logearav
    Coulomb's law Law
The forum discussion revolves around solving a problem using Coulomb's law involving two point charges that sum to 6µC and attract each other with a force of 0.9 N when separated by 40 cm in a vacuum. The correct interpretation of the equations is crucial; the charges must be defined correctly as one positive and one negative. The final correct charges are q1 = 8µC and q2 = -2µC, derived from the equations q1 + q2 = 6µC and the application of Coulomb's law. Misinterpretations of the equations led to confusion regarding the signs of the charges.
  • Coulomb's law and its mathematical formulation
  • Basic algebra for solving equations
  • Understanding of electric charge properties (positive and negative)
  • Concept of forces between charged particles
  • Study the derivation and applications of Coulomb's law in electrostatics
  • Learn about the concept of electric field and potential
  • Explore the principles of superposition in electrostatics
  • Investigate the relationship between charge, force, and distance in electrostatic interactions
Students studying physics, particularly those focusing on electrostatics, as well as educators and anyone looking to deepen their understanding of charge interactions and Coulomb's law applications.
logearav
The sum of two point charges is 6µC. They attract each other with a force of 0.9 N, when kept 40 cm apart in vacuum. Calculate the charges.
q1+(-q2) = 6x10-6
q1-q2=6x10-6...I
q1=6x10-6+q2
According to Coulomb's law
F=q1q2/4πε0r2
.9=(6x10-6+q2)q2/4πε0(.4)2
.9=(6x10-6q2+q22)x9x109/.16
.144/9x109=6x10-6q2+q22
144x10-3x10-9/9=6x10-6q2+q22
q22+6x10-6q2-16x10-12=0
(q2+8x10-6)(q2-6x10-6)=0
q2=-8µC or q2=6µC
The answers given in the book are q1 = 8micro Coulomb and q2= -2 microcoulomb
I don't understand how to get this answer because when q2 = 8 microcoulomb and substituting in equation I , i get q1+8micro coulomb =6 micro coulomb so q1 should be -2 micro coulomb
Did i miss anything in the steps? Members, please help me .
logearav said:
q1+(-q2) = 6x10-6
q1-q2=6x10-6...I
q1=6x10-6+q2
Since you're assuming that q1 is positive and that q2 is negative, you don't need to wedge in that extra minus sign. Just write q1 + q2 = 6x10-6C.
F=q1q2/4πε0r2
Since one of the charges is negative the product q1*q2 will be negative, and thus the force should be negative also.
Let f = 0.9N, r = 0.40m, Q = 6μC, k = \frac{1}{4 \pi \epsilon_o} Then
Q = q_1 + q_2 so that q_2 = Q - q_1
f = -k \frac{q_1 q_2}{r^2} = -k \frac{q_1 (Q - q_1)}{r^2}
it has been mentioned that two charges attract each other that's why i took q2 as negative. is my assumption wrong, sir?
No, the assumption is fine. Oppositely signed charges attract. Either q1 or q2 must be negative (but not both!).
Thanks a lot for the reply, sir. Then why i didn't get the correct answer when i framed the equation q1-q2= 6 micro coulomb, taking q1 as positive and q2 is negative. I got the correct answer when i proceeded as suggested by you. But what's wrong with my assumption?
q1 - q2 is the difference between the charges, not the sum of the charges.
I got it sir. Thanks a lot for patiently helping me.
10K
