Coulomb's Law and stationary proton
The discussion revolves around a physics problem involving Coulomb's Law and the equilibrium of forces acting on a stationary proton and an electron. The original poster is trying to determine the distance at which an electron is suspended under a proton, balancing the gravitational force with the electromagnetic force.
  • The original poster attempts to equate the electromagnetic force and gravitational force but is unsure how to apply Coulomb's Law correctly. Some participants clarify the formula for Coulomb's Law and discuss the relationship between the charges of the proton and electron. Questions arise regarding the use of the same charge value for both particles and the reasoning behind squaring the charge.
Participants are actively engaging with the problem, offering clarifications on the formulas and the reasoning behind them. Some have provided guidance on how to set up the equations, while others are exploring different interpretations of the problem. There is a sense of progress as participants share insights and resolve misunderstandings.
There are variations in the formulas referenced by participants, with some using different notations for Coulomb's Law. The discussion also touches on the assumptions regarding the charges of the proton and electron being equal in magnitude but opposite in sign.
Cyto
Yeah, I'm having difficulties with this one question...
A stationary proton holds an electron in suspension underneath it against the force of gravity. How far below the proton would the electron be suspended?
I understand that Fe = Fg
so i would have __ = mg...
but i don't know what to fill the __ to get an answer... I've tried using
Eq = mg... but that doesn't seem to get me anywhere.. can anyone show me my error and point me on the right path?
The force due to electromagnetic force is Coulomb's law,
F_e = \frac{q_1 q_2}{4 \pi \epsilon_0 r^2}
where \inline{q_1} and \inline{q_2} are the magnitude of the charges in coulombs, and \inline{r} is their separation in meters.
The force due to gravity you already have:
F_g = m g
The force pulling the electron up is given by Coulomb's law. The force pulling the electron down is given by the previous equation. Set them equal to each other, and solve for r.
Does this help?
- Warren
we didn't have the same formula for coloumb's law... we had
Fe= kq1q2 / d^2
Fe= kq1q2 / d^2
That's actually the same formula. Someone along the line decided to make a new variable,
k = \frac{1}{4 \pi \epsilon_o}
just so Columb's law would look more similar to Newton's law of gravitation,
F_g = \frac{G m_1 m_2}{r^2}
Also, they called the separation d instead of r, but it's the same quantity.
- Warren
I'm going to use Fe for electric force and Fg for gravity force.
Fe = Fg
kq^2/d^2 = mg
(9x10^9)(1.6x10^-19)^2 / d^2 = (9.11x10^-31)(9.81)
To solve I just graphed it and looked for the intersection.
d = 5.0774m
d = 5.08m
why did you square the 1.602x10^-19... like i would understand that to substitute that into q1, but why q2 also?? This is basically why i was having problems with the question.. if i knew you could use the same value for both q1 and q2 i would have never asked this...
BTW that is the right answer...
protons and electrons have the same charge, that makes it squared.
well that makes sense now... thanks a lot all of you guys... man, I'm soo happy i found this website...
Take it step by step.
-\frac{k q_1 q_2}{d^2} = m g
Solve for d:
-k q_1 q_2 = m g d^2
d = \sqrt{\frac{-k q_1 q_2}{m g}
Since your problem deals with a proton and an electron, which have opposite but equal charges, the quantity
q_1 q_2 = -e \cdot e = -e^2
where \inline{e} is the charge on the electron (and proton).
Plug that into the equation above to get
d = \sqrt{\frac{k e^2}{m g}
- Warren
sweet.. i got the answer, thanks guys...
10K
9K
  • · Replies 16 ·
  • · Replies 19 ·
