Coulomb's Law: Determining the velocity of a charge when far apart
The discussion focuses on calculating the velocity of three identical charges, each with charge 'Q' and mass 'm', arranged in an equilateral triangle of side length 'L' when they are far apart. The solution involves applying the conservation of energy principle, where the potential energy (PE) of the system is equated to the kinetic energy (KE) of the charges. The final velocity formula derived is v = √[(2kQ²)/(mL)], where 'k' is Coulomb's constant, and 'L' is the distance between the charges.
  • Coulomb's Law and its application in electrostatics
  • Understanding of kinetic and potential energy concepts
  • Basic algebra for manipulating equations
  • Familiarity with the conservation of energy principle
  • Study the derivation of Coulomb's Law and its implications in electrostatics
  • Explore the conservation of energy in different physical systems
  • Learn about potential energy calculations for multiple charge systems
  • Investigate the dynamics of charged particles in electric fields
Students studying physics, particularly those focusing on electrostatics and energy conservation, as well as educators seeking to clarify concepts related to charge interactions and energy transformations.
lilpoopoo
"Three identical charges, each with charge 'Q' and a mass 'm', are arranged on the corners of an equilateral triangle of side length 'L'. The spheres are released simultaneously. What is the speed of each charge when they are very far apart?
F = [(kq1q2)/r2] * r^
F = ma
Since all of the charges are the same, and they are equidistant from one another, then the force on each should be identical.
I calculated the force on one charge (A) from the other two (B & C).
Therefore:
Fon A = (kQ2(root 3/4 L2))/L3
or (kQ2sin(60))/L2
So for each individual charge, the force on A should be the same, as above, for B & C.
My issue is that I can't figure out how to calculate the velocity from this...
Or am I going completely in the wrong direction? :frown:
Edit: Forgive my equations, I haven't figured out how to make them nice. It's my first post.
Hi lilpoopoo. Welcome to Physics Forums.
Did you consider looking at the problem from a conservation of energy point of view?
Hi gneill. Thanks :)
Okay, so I did what you suggested, not sure if it's correct though.
So we know the potential energy difference is:
V = (kq)/r​
And we know
PE = KE​
Therefore:
1/2 mv2 + 1/2 mv2 + 1/2 mv2 = (kq)/r + (kq)/r + (kq)/r​
v = root [(2kQ)/(mr)]​
I'm not sure about the 'r' part. Would that be the distance from the horizontal line drawn between the two charges at the base of the triangle up to the top charge at the apex, which is root (3/4 L2)?
You're on the right track, but your electric potential calculation needs a tiny bit of massaging.
You're looking for the potential energy stored in the system when it's assembled in the triangle form. To calculate the potential energy you take the charges involved pairwise and calculate the individual potential energies, and sum them up. This appears to be what you were going for in your equation above. However, the potential energy for a pair of charges Q1 and Q2 separated by distance R (center to center distance) is:
PE = k\frac{Q1\;Q2}{R}
Note that the both Q values are required. Thanks to the particular triangular layout, the distance between all the charges is the same, L.
Okay, so doing the pairwise additions would yield:
(3/2) mv^2 = (kQ1Q2)/R + (kQ2Q3)/R + (kQ1Q3)/R
And since each charge is the same, +Q, and the charges are all 'L' distance apart:
(3/2) mv^2 = (kQ^2)/L + (kQ^2)/L + (kQ^2)/L
Therefore:
v = root [(2kQ^2)/(mL)]
:rolleyes:
Edit: Also, is there a way to easily access our own posts? I just keep looking for it with search terms.
The primary forum page has the list of threads. If you've registered with a valid email address, then email notifications of additions to threads that you are subscribed to will be sent to it.
You can also select "My Pf" at the top of the page. If you don't see your thread i n the main section (perhaps it's no longer a "new" thread"), you can always select "List Subscriptions" under "My Control Panel". Your thread should show up there.
Personally, I tend to use the email notifications to find things. I just hit the link in the message and the browser opens to that message.
Oh, alright. Got it. Thanks :)
So was my solution correct?
It looks okay to me. Why, aren't you happy with it? :smile:
Haha, no. Just unsure. Physics doesn't come easy for me. Thanks so much for your help.
