Coulombs Law find the magnitude and direction ?
The discussion revolves around Coulomb's Law and the calculation of electric forces between point charges. The original poster expresses confusion regarding the magnitude and direction of forces acting on three point charges positioned along the x-axis.
  • Participants discuss the setup of the problem involving three charges and the application of Coulomb's Law. Questions arise about interpreting the micro symbol for charge and understanding the superposition principle. There is also a focus on determining the direction of forces and how to represent them as vectors.
Some participants have provided clarifications on the meaning of micro-Coulombs and the formula for calculating forces. Guidance has been offered regarding the superposition principle and the importance of considering directions in force calculations. The original poster continues to seek further clarification on vector directions and their representation.
The original poster mentions a recent transition from studying lenses to electric forces, indicating a potential gap in foundational understanding. There is also a request for calculator programs to assist with physics calculations.
airforce840
We are dealing with Coulombs law or w/e in Physics right now AND I DONT GET IT lol In my homework. it gives numbers like +6.0 (weird u symbol)C and i jus don't understand how to find the magnitude and direction of everything..
Im a junior in Physics..so someone of higher class...like..college...that could help.. PLEASE HELP ME! lol
Patrick :confused: :eek:
Well, do you have a sample problem you have trouble understanding with... If so post it.
ok... here's a sample prob. actually its the one I am on..
1. Three point charges, q1, q2, and q3, lie along the x-axis at x=0, x=3.0 cm, and x= 5.0 cm, respectively. Calculate the magnitude and direction of the electric force on each of the three point charges when q1= +6.0 mu symbol C, q2=+1.5 muC and q3= -2.0 muC.
This all deals with "the superposition principle" and yea..this is hard stuff considering we were just working with lens...and i hated them and wish we were back to them already lol.
patrick
The "weird u symbol" you speak of means micro, which is 1 * 10^-6. So 6 \mu C is the same thing as 6 \cdot 10^{-6} C. Remember that the equation for force between two charges is F=\frac{kq_{1}q_{2}}{r^{2}}
ok, calm down. This isn't really that hard, it's just in a new format. I assume that you've done gravity? F=\frac{G m_{1} m_{2}} {r^2}? Well coulomb's law is basically the same. Instead of G you have k, and instead of masses you have charges. So for the force between two charges, you just put q1 as one charge (say q1=+6.0 muC) and q2 as the other charge (say 1.5muC) and the r is the distance between them (say 3.0cm). so you just plug those numbers into the equation and you've got the force between those two charges. If say q2=-2.0muC then the force would be negative (the negative charge q2 times the positive charge q1).
Now superposition is really not that difficult either. Basically, if you have three charges, q1, q2, and q3, the TOTAL force on q1 is the force on q1 by q2 PLUS the force on q1 by q3. And there you go. You've got the force. Just a small hint: Don't forget the directions of the force. If one of the force is negative, take that into account. If you have three charges and your looking for the force on the one in the middle, don't forget which way each force is going. You'll understand the hint better once you do the problem.
F = k\frac{q_1q_2}{r^2}
When the magnitude of the force is positive (negative-negative or positive-positive) then it is a push force, pointing away from the other charge.
When the magnitude of the force is negative (negative-positive) then it is a pull force, pointing to the other charge.
Also you will usually see charges in micro-Coulombs: \mu C, which is a milionth of a Coulomb. The SI unit C is usually considered too large for normal static charges, which are just a few \mu C or nC (nano-Coulombs, or bilionth of a Coulomb).
Thanks 4 the Help
I got to class and had some more explanation... i wish in class they would be as blunt and understandable though... only thing i still have a problem with is like.. trying to find the vectors part..the directions.. like
q1 q2
q3 q4 i don't understand after finding the Forces acting on them..like the directions...which comes out as a Degree.. its jus...confusing i guess..i don't know how to explain in on here lol. easier by mic.
but thanks for the help.. anyone have calculator programs for physics? i have a ti -84 plus...
patrick :smile:
9K
10K
11K
11K
