Coulomb's Law involving triangle
The discussion focuses on a physics problem involving Coulomb's Law and two-dimensional motion with three point masses, each having a charge of +15 Coulombs and a mass of 5.5 kg. The fixed mass 1 is positioned 1.5 m above mass 2, which is on the ground, while mass 3 approaches mass 2 from the right. The key challenge is determining the distance at which mass 3 can approach mass 2 without causing it to move, factoring in the forces exerted by mass 1 and the kinetic friction acting on mass 2.
  • Coulomb's Law (F=KQ/R^2)
  • Newton's Second Law (F=MA)
  • Understanding of kinetic friction and its coefficient
  • Basic principles of energy conservation in physics
  • Study the application of Coulomb's Law in two-dimensional systems
  • Learn how to calculate forces in a free body diagram context
  • Explore the relationship between kinetic friction and motion in physics
  • Investigate energy conservation principles in dynamic systems
Students studying physics, particularly those focusing on electrostatics and mechanics, as well as educators looking for practical examples of applying Coulomb's Law in real-world scenarios.
Benny851
There are three point masses. 1 is fixed in space with the 2nd point mass directly below it on the ground. The 3rd point mass is an unknown distance to the right of mass number 2. These 3 point masses for a rt triangle with point 2 at the 90 degree angle. The vertical distance between point mass 1 and 2 is 1.5 m. The mass of each point mass is 5.5kg. Also there is kinetic friction between point mass 2 and the ground. All three point masses have a charge of +15 Coulombs. If mass 3 starts moving toward mass 2, how far away from 2 will 3 be when 2 starts to move?
F=MA
F=Eq
F=Qq/r^2
F=KQ/R^2
This problem seems to combine coulomb's law with with 2-d motion. However, I am stumped as to how to combine the 2 concepts. also, not knowing the original starting distance between 3 and 2 is complicating matters.
I am able to calculate the force that 1 exerts on 2 no problem but have no idea how to figure out the force that 3 exerts on 2. i also have no idea how to incorporate friction
It is the same as normal only now you know the origins of the forces.
Draw a free body diagram for mass 2.
I see what you mean. So the force acting on 2 is equal to the frictional coefficient*(mg + force of 1 acting on 2), right.
I'm thinking I use the conservation of energy equation to determine how far 3 is from 2 when 2 starts to move, is that right?
How does conservation of energy help here?
Why not just add up all the forces - you know what they have to sum to?
Keep the variables (it helps that all the masses and charges are the same) and solve for the distance to charge 3.
I am a little confused still. I have calculated the original distance between 2 and 3 before 3 starts to move from the right. Does 2 start to move at same time 3 starts to move, if so then the original starting distance is the distance from 2 that I am solving for.
Of course not :)
3 starts out so far away that the friction is enough to hold 2 where it is.
As 3 approaches 2, the coulomb force increases - at some point the force will be so large that the friction no longer holds 2 in place.
All the problem wants to know is how close 3 can get to 2 without 2 moving.
