Counter intuitive melting temperatures
  • Context: Undergrad
  • Thread starter Thread starter JizzaDaMan
    Counter Melting
The discussion revolves around the melting and freezing points of helium and hydrogen, exploring why helium has a lower melting point despite its higher mass. Participants delve into the underlying physical principles, including molecular interactions and thermal movements, while also touching on related comparisons with nitrogen and carbon.
  • Some participants assert that helium has a lower melting point than hydrogen, questioning the reasons behind this counterintuitive observation.
  • One participant provides specific melting point values for helium (1.1K) and hydrogen (14.175K) but does not explain the underlying reasons.
  • A participant discusses the role of molecular mass and binding energy, suggesting that heavier molecules like hydrogen have more inertia, which complicates the relationship between mass and melting point.
  • Another participant explains that helium's tightly bound electron clouds result in weaker London forces compared to hydrogen, affecting their melting points.
  • There is mention of zero point movements of nuclei and their influence on molecular bonding, with a focus on how these movements differ between hydrogen and deuterium.
  • One participant expresses confusion about the concept of zero point movements, prompting further clarification from another participant.
Participants generally agree that helium has a lower melting point than hydrogen, but the reasons for this remain contested and not fully resolved. There are differing interpretations of the physical principles involved, particularly regarding molecular interactions and thermal dynamics.
The discussion includes complex concepts such as zero point movements and London forces, which may require further elaboration for complete understanding. Some assumptions about molecular behavior and interactions are not fully articulated.
Readers interested in physical chemistry, thermodynamics, and molecular physics may find this discussion relevant, particularly those exploring the properties of gases and phase transitions.
JizzaDaMan
I have heard that the melting/freezing point of helium is lower than that of hydrogen. Is this correct? if so why?
My thoughts on this are that hydrogen has the lowest mass and therefore requires less energy than helium to be in a liquid or gaseous state, so it appears counter intuitive that the melting point of helium is lower than that of hydrogen.
Science news on Phys.org
the melting point of helium is 1.1K,or -272.05°C,or-458°F the melting point of hydrogen is 14.175K,or-258.975°C,or-434°F the reasn for this i don't know but i hope this helps
Melting point of nitrogen is also lower than that of carbon.
The thermal movement of molecules is not working agains mass. True, heavier molecules move slower; but they also have more inertia. The main effect is that the thermal movement works against binding energy. Carbon atoms in graphite are bound by strong covalent bonds and extreme heat is needed to break them; strong covalent bonds also bond two nitrogen atoms to a molecule, but the bonds between nitrogen molecules are feeble London forces.
The London forces which bind to each other molecules of nitrogen, or paraffin, or hydrogen, or atoms of helium or neon, are forces which only connect electron clouds. It is only some higher order effects which depend on mass of the nuclei inside the clouds.
Helium, being an inert gas, has very small, tightly bound electron clouds. They are very hard to polarize and thus have weak London forces, compared to the bigger, looser and more polarizable electron clouds of hydrogen molecules.
The higher order effects come from zero point movements of the nuclei inside. Just like electrons cannot fall onto nuclei but have to undergo orbital movements and spread out as electron clouds, nuclei cannot occupy a single position in a molecule or crystal. Both hydrogen and deuterium atoms need some space to move around in crystal - but since the electrons follow the nuclei in zero point movements, this weakens the bonds which the electrons make. And weakens them more for protium than for deuterium, whose nuclei are more massive and have lower amplitude of zero point motion.
Also, boiling points generally have more regular systematic trends than melting points, because they are not so dependent on specifics of crystal structure.
Thanks snorkack, most of that makes sense to me, just this paragraph that confused me a little:
What do you mean by zero point movements?
I think I explained it. Oscillations around the potential minimum position.
You might have done but it wasn't fully clear to me :P thanks a lot, that's much clearer to me
9K
  • · Replies 16 ·
  • · Replies 16 ·
