Deven Patel
Hello PF community!
Quick introduction: I'm a fresh-out-university mechanical engineer working on a telescope altitude-azimuth mount hobby project. The mount will be designed using rotary platforms (powered by internal motors) to move the mount structure in the altitude and azimuth directions (1 for each direction).
The base of the mount structure has two purposes: 1. to support the weight of the upper mount (for the telescope) and 2. to rotate the entire structure in the azimuth direction (which will be done by 1 rotary platform that will be fixed underneath the base). The upper mount (that is holding the telescope) needs to have freedom in the altitude direction, it will be rotated by the second rotary platform that will be fixed on one side of the entire structure and needs to couple the two mounts together. Refer the picture below for a visual layout of the current design. The rotary mount underneath the structure is not shown, the rotary mount that needs to couple the two mounts is on the right. It is currently interface to the telescope mount by a custom mechanical interface piece that I designed. The large, black cylinder near the top of the picture is the telescope, the 5 small, black cylinders are the counterweights, to balance the CG of the upper mount structure.
Being an amateur mechanical engineer and never having worked with dynamic parts, I'm lost on how to design the coupling between these two mounts. The rotary platform underneath the base should be ok, but the one that's coupling the two mounts together is a problem because it's being used in an application that it's not really meant for. Generally speaking, a motor transmits torque to a mechanical piece through shaft-key or gear-pulley assemblies; but, in this case, I need to transmit torque from a rotary platform to a mechanical piece. Does anyone have any thoughts about how this can be accomplished? With the rotary platform fixed to the base mount, is a direct mechanical piece to interface the rotary platform to the upper mount the best approach?
FYI, the rotary platforms I'm using are the RM-8 (underneath base mount) and RM-5 (coupling the two mounts) rotary stages by Newmark Systems. Side note: I'm using these rotary platforms because they're what was available to me so I'm trying to make do with them so I don't have to invest more money into the project!
Thanks for the help in advance, I'll reply to messages in a timely manner!
Deven Patel
Deven Patel
