Coursework help? Moment of inertia/radius of gyration/velocity question
  • Thread starter Thread starter bobmarly12345
    Coursework Moment
The discussion centers on a physics problem involving the coupling of an engine to a rotating drum via a friction clutch. The engine has a moment of inertia equivalent to a mass of 40 kg with a radius of gyration of 112 mm, while the drum has a mass of 12 kg and a radius of gyration of 129 mm. The initial velocity of the engine is 11 rev/s, and the drum starts from rest. The solution requires applying the principle of conservation of angular momentum to find the combined velocity of the engine and drum immediately after connection.
  • Understanding of moment of inertia and radius of gyration
  • Knowledge of angular momentum conservation principles
  • Familiarity with rotational dynamics
  • Basic algebra for solving equations
  • Study the conservation of angular momentum in rotational systems
  • Learn how to calculate moment of inertia for various shapes
  • Explore the effects of friction clutches in mechanical systems
  • Practice solving problems involving coupled rotating bodies
Students in physics or engineering disciplines, particularly those studying dynamics and rotational motion, will benefit from this discussion.
bobmarly12345
Coursework help!? Moment of inertia/radius of gyration/velocity question
An engine is suddenly coupled to a rotating drum by a friction clutch. The moment of inertia of the engine is equivalent to a mass of 40Kg acting with a radius gyration of 112mm. The drum has a mass of 12Kg and a radius of gyration of 129mm. The initial velocity of the engine before engagement is 11 rev/s and the drum is initially at rest. Find the velocity of engine and drum immediately after connection.
Have no idea where to start, any help would be great thanks?
welcome to pf!
hi bobmarly12345! welcome to pf! :smile:
this is a collision, so energy isn't conserved, but angular momentum is conserved
so use conservation of angular momentum …
what do you get? :smile:
18K
  • · Replies 40 ·
11K
