Covariant derivative and geometry of tensors
The discussion revolves around understanding the covariant derivative and the geometry of tensors within the context of general relativity, particularly as presented in Wald's text. Participants explore foundational concepts in differential geometry, the nature of smooth vector fields, tensor products, and parallel transport, seeking clarity on these complex topics.
  • One participant expresses confusion about the connection between tangent spaces and smooth vector fields, questioning how smooth vector fields can exist without a covariant derivative.
  • Another participant argues that the closeness of tangent vectors depends on the coordinate system, suggesting that coordinate derivatives allow for comparisons independent of local coordinates.
  • Participants discuss the limitations of using R^n to understand tangent spaces, with one noting that smoothness does not depend on a chart, while another references Dirac's work on parallel transport using embeddings.
  • Concerns are raised about the geometric interpretation of tensor products and contractions, with one participant seeking a clearer understanding of the meaning behind operations like raising and lowering indices using the metric.
  • Some participants suggest looking at alternative texts for better explanations of parallel transport and tensor operations, mentioning works by Bishop and Crittenden as well as Schutz.
Participants exhibit a mix of agreement and disagreement on the interpretation of smooth vector fields and the use of R^n. There is no consensus on the best way to visualize tensor operations or the geometric meaning of tensor products, indicating ongoing uncertainty and exploration of these concepts.
Participants note that the understanding of tensor operations may depend on the specific mathematical framework being used, and that different texts may approach these concepts with varying degrees of rigor and clarity.
This discussion may be useful for students and self-learners of general relativity and differential geometry, particularly those seeking deeper insights into the geometric interpretation of tensors and the covariant derivative.
avorobey
I'm trying to teach myself GR from Wald's General Relativity, and it's very tough going. I do have basic knowledge of differential geometry, but I think my geometric intuition is next to nonexistent. I'd very much appreciate some help in understanding several basic questions, or pointers to texts with good explanations.
1. The text stresses that in the absence of something like covariant derivative, we have no way of connecting tangent spaces of different points with each other. What confuses me is how can we have a notion of a smooth vector field in that case? I understand the definition of a smooth vector field (tangent vectors acting as derivations turn smooth functions to smooth functions); since we have it, doesn't it mean that we do have a notion of what it means for tangent vectors from two nearby tangent spaces to be very close?
Also, why doesn't the standard trick of passing to R^n work? Given two nearby points on the manifold, why can't we translate them into R^n by a chart and identify their tangent spaces in R^n? If this leads to different results in different charts, why wouldn't the smoothness of chart transformations make everything alright, and is there an instructive example to show this failure?
2. Is there a good way of understanding tensor product and contraction geometrically? I can follow all the indices around, I just completely fail to understand what it *means*, and it's very frustrating. For example, Wald defines parallel transport of vector [tex]v^{b}[/tex] along a curve with tangent [tex]t^{a}[/tex] by the equation [tex]t^{a}\nabla_{a}v^{b} = 0[/tex]. But I don't understand why this should capture the notion of parallel transport. [tex]\nabla_{a}v^{b}[/tex] is some (1,1)-tensor, and while I can write out the definition of what it means to multiply it by [tex]t^{a}[/tex] and contract over index a, I don't really understand what it means. Even worse, for a general tensor T with both covariant and contravariant indices, I have no clue how to imagine [tex]t^{a}\nabla_{a}T = 0[/tex]. Is there a helpful way to visualize/understand this?
Many thanks in advance!
No, because how close they are depends on a coordinate system. When you have a coordinate derivative, you can compare tangent vectors at different points depending on a path that connects these two points but is independent of a a local coordinate system.
Smoothness does not depend on a chart, but other things do depend.
Tesnor products of vector space is a part of multilinear algebra. Some of that has a geometrical interpretation in terms of Grassmann (or Clifford) algebra. But otherwise algebra is just algebra - a very useful tool.
It is good to check some other book where these concepts are explained in detail, especially parallel transport along along a path. I like Bishop, Crittenden "Geometry of manifolds", but you will certainly find other good books.
It does, at least formally. See, for example, Dirac, General Theory of Relativity, section 6, where he uses an embedding to define parallel transport. Try searching in the forum for some interesting discussions of how big an n you need. (Oops, sorry, you're right, OP is not asking about that.)
[tex]t^a\nabla_a[/tex] is how one writes out the directional derivative along the curve in Wald's s notation. It's the same as
[tex]t^a \nabla_{\frac{\partial}{\partial x^a}} = \nabla_{t^a\frac{\partial}{\partial x^a}}[/tex]
in Koszul notation, where it's easier to see that it's the covariant derivative in the direction of the tangent vector field..
I don't think this is what the OP was asking about when he asked his question in the context of smoothness. Moreover the embedding trick is not really "geometrical", because it works on an infinitesimal level as regards the law of the parallel transport.
Right, I understand this. What I meant is, about the most typical thing that I see done with two tensors in Wald's book so far, is multiplying them and contracting the product on one of the indices. For example, this is done all the time to raise/lower indices using the metric; but while I understand the formalism and see that it e.g. changes an (n,m) tensor into (n-1,m+1), I don't understand the *meaning* of the operation.
I worked out that if I have a dual vector and a vector, and if I treat them as tensors and multiply then contract those tensors, what I get is the same as simply acting on the vector with the dual vector. That's about the simplest example imaginable, and that's now clear to me. But I completely lack intuition into what it means e.g. to tackle on the metric to an (n,m) tensor, contracting on one index. Sure, formally it's a (n-1,m+1)-tensor, a multilinear function on n-1 V*'s and m+1 V's, and given a sample set of n-1 dual vectors and m+1 vectors, I can write out the formula of the value of the function as a sum over one basis of a product of the metric values and the original tensor's values. But that formal sum is all I have; I can't help thinking I should have some kind of (vague? geometric? algebraic?) intuitive understanding of what was actually *done*.
Anyway, I wanted to thank you, and Daverz, for your kind answers and some pointers. I've also started reading Schutz's GR book, and it seems to go into more details setting up tensors and covariant derivatives (only just getting to that part); perhaps it'll clear things up for me. I've looked at Bishop & Crittenden and it's also very nice, though perhaps a bit more mathematically-minded than I need for getting through Wald (e.g. they discuss everything in terms of arbitrary fiber bundles, while Wald only looks at the tensor bundle w/o calling it so); but I'll try looking things up there when they're too vague for me elsewhere.
avorobey said:
For example, this is done all the time to raise/lower indices using the metric; but while I understand the formalism and see that it e.g. changes an (n,m) tensor into (n-1,m+1), I don't understand the *meaning* of the operation. .
I think it all boils down to the question what is the geometrical (or whatever) *meaning* of the trace of a matrix. All these contractions are generalized partial traces. These are *invariants*. In physics we are trying to associate some geometrical and geometrical content to the invariants and to invariant operations. For some it is easy, for some it is not so easy. In quantum theory we are even taking traces over a continuous index, like x or p - we call then "integrals".
You might try the Stanford Leonard Susskind lectures on General Relativity (GR starts at lecture 28):
http://academicearth.org/courses/foundations-of-modern-physics
or you can just google: "Stanford Susskind Lectures" and more places to get or view the video will show up. They are also available via iTunes University.
I found the discussion of parallel transport to be easy to understand. His treatment of covariant derivatives is also good.
  • · Replies 28 ·
  • · Replies 124 ·
10K
  • · Replies 16 ·
  • · Replies 33 ·
