Crank Nicolson method to solve a PDE
23 replies · 5K views · last reply
hanabachi
Hello,
I wrote a code to solve a non-linear PDE using Canrk nicolson method, but I'm still not able to get a correct final results. can anyone tell me what wrong with it?
There is a bug on line 42 :wink:
If you don't post the code, there is not much anyone can do.
I though the code is visible in the attached files. Thank you for letting me know
What's the maximum timestep you can use and still have the method be stable? Are you exceeding it?
Here is the code
Matlab:
%% Crank-Nicolson Method
clear variables
close all
% 1. Space steps
xa = 0;
xb = 1;
dx = 1/40;
N = (xb-xa)/dx ;
x = xa:dx:xb;
%2.Time steps
ta = 0;
tb = 0.5;
dt = 1/3300;
M = (tb-ta)/dt ;
t = ta:dt:tb;
%3. Controling Parameters
%4. Define equations A, B , C and phi(x,t)
A = @(x,t) (50/3)*(x-0.5+4.95*t);
B = @(x,t) (250/3)*(x-0.5+0.75*t);
C = @(x,t) (500/3)*(x-0.375);
phi = @(x,t)(0.1*exp(-A(x,t)) +0.5*exp(-B(x,t))+exp(-C(x,t)))./...
(exp(-A(x,t)) +exp(-B(x,t))+exp(-C(x,t)));
% 5 Initial and boundary conditions
f = @(x) phi(x,t(1)); % Initial condition
g1 = @(t)phi(x(1),t); % Left boundary condition
g2 = @(t)phi(x(N+1),t); % Right boundary condition
r = dt / (2*dx^2);
a = -0.003*r;
b = 1 + 2*0.003*r;
c = -r*0.003;
d =(1+0.003*2*r);
e =1+0.003*2*r;
h =0.003*r;
% 6 Implementation of the explicit method
U = zeros(N+1,M+1);
U(2:N,1) = f(x(2:N)); % Put in the initial condition
U(1,:) = g1(t); % The boundary conditions, g1 and g2 at x = 0 and x = 1
U(N+1,:) = g2(t);
for i = 2:N
     RHS= (1+2*0.003*r)*U(i,N)+0.003*r*U(i+1,N)+0.003*r*U(i-1,N)-r*dx*U(i,N)*(U(i,N)-U(i-1,N));
end
for j=2:M % Time Loop
    for i= 2:N % Space Loop
       RHS= (1+2*0.003*r)*U(i,N+1)+0.003*r*U(i+1,N+1)+0.003*r*U(i-1,N+1)-r*dx*U(i,N+1)*(U(i,N+1)-U(i-1,N+1));
    end
end
% Make some plots
T= 0:.1:M;
V = [];
for i= 1: length(T)
    P = find(t==T(i));
    V = [V P];
end
figure
subplot(131)
for j = 1:length(V)
hold on
plot(x,U(:,V(j)),'*-','linewidth',2.5,'DisplayName',sprintf('t = %1.4f',t(V(j))))
end
legend('-DynamicLegend','location','bestoutside');
a = ylabel('U-Values');
set(a,'Fontsize',14);
a = xlabel('X-Values');
a=title('Crank-Nicolson Solution');
set(a,'Fontsize',16);
grid;
% disp(u(:,V)'); % Each row corresponds to a particular value of t and
% Each column corresponds to a particular value of x
% Implement the exact solution and compare it to the exact solution
Exact =@(x,t) phi(x,t);
subplot(132)
for j = 1:length(V)
hold on
plot(x,Exact(x,t(V(j))),'*-','linewidth',2.5,'DisplayName',sprintf('t = %1.4f',t(V(j))))
end
a=title(' Analytical Solution');
grid;
[X,T] = meshgrid(x,t);
% Exact2 = (0.1*exp(-A(X,T)) +0.5*exp(-B(X,T))+exp(-C(X,T)))./...
% (exp(-A(X,T)) +exp(-B(X,T))+exp(-C(X,T)));
Error =abs(Exact(X,T)'-U);
subplot(133)
for j = 1:length(V)
hold on
plot(x,Error(:,(V(j))),'*-','linewidth',2.5,'DisplayName',sprintf('t = %1.4f',t(V(j))))
end
a = ylabel('Error');
a=title(' Absolute Error ');
grid;
<mentor edit code tags>
I used this dt = 1/3300
Well, to me it looks like you're not actually solving anything, you've just created a 2D matrix U and filled it.
You need to solve a matrix-vector system $$Ax=b$$ for your entire spatial domain at every time step. What is your matrix A and your vector b? Do you have lecture notes explaining how the Crank-Nicolson method works?
Have a look at the very simple 1D diffusion problem at wikipedia:
https://en.wikipedia.org/wiki/Crank–Nicolson_method
In this example you try to solve the diffusion problem
$$\frac{\partial u}{\partial t} = a \frac{\partial^2 u}{\partial x^2} $$, and the discretization scheme leads to:
$$-r u_{i+1}^{n+1} + (1+2r)u_i^{n+1}-ru_{i-1}^{n+1}=ru_{i+1}^{n}+(1-2r)u_i^{n}+ru_{i-1}^n, $$
with
$$r=\frac{a\Delta t}{2(\Delta x) ^2}$$.
The temporal and diffusion terms adds to the matrix A as well as the vector b as you move everything known at timestep t to the right and you keep the unknown terms at timestep t+1 in the matrix at the left. Can you construct the matrix A and vector b from this example?
actually the equation is
dU/dt=0U*du/dx+0.003*dU2/dx2
This is linear. I assume 0U is a typo though?
Actually the partial differential equation is:
$$ \frac{\partial u}{\partial t} = -u\frac{\partial u}{\partial x} + 0.003 \frac{\partial^2 u }{\partial x^2}, x \in (0,1), t>0$$
But the question is to solve it using the Crank-Nicolson method. Do you have the difference scheme for this PDE and can you reproduce it here? We can continue from there.
0 should be negative signs (-), so the equation is the multiplication of U by its first derivative dU/dx. So the equation is not linear
Can you please type it here in latex? My eyes are still hurting from looking at this document :-)
hanabachi said:
Yes, this is what I'm using to solve the pde. please check the attached file
Please be aware that a lot of people simply refuse to download data trash, i.e. documents that have to be deleted after use. I, for example. If it is too troublesome for you to type it out here, then it is too troublesome for me to download whatever you want to force me to.
Here is explained how you can type formulas on PF: https://www.physicsforums.com/help/latexhelp/
yes, here it is
\begin{array}{l}
\frac{U_{i}^{n+1/2} -U_{i}^{n}}{\Delta t/2} =-U_{i}^{n}\frac{U_{i}^{n} -U_{i-1}^{n}}{\Delta x} \ +0.003\ \frac{U_{i+1}^{n} -2*U_{i}^{n} +U_{i-1}^{n}}{\Delta x^{2}}\\
\frac{U_{i}^{n+1} -U_{i}^{n+1/2}}{\Delta t/2} =-U_{i}^{n+1}\frac{U_{i}^{n+1} -U_{i-1}^{n+1}}{\Delta x} \ +0.003\ \frac{U_{i+1}^{n+1} -2*U_{i}^{n+1} +U_{i-1}^{n+1}}{\Delta x^{2}}\\
adding\ ( 1) \ and\ ( 2)\\
r=\frac{\Delta t}{2\Delta x^{2}}\\
U_{i}^{n+1} +r*\Delta x*U_{i}^{n+1}\left( U_{i}^{n+1} -U_{i-1}^{n+1}\right) -0.003*r\left( U_{i+1}^{n+1} -2U_{i}^{n+1} +U_{i-1}^{n+1}\right) =\\
\ U_{i}^{n} -r*\Delta x*U_{i}^{n}\left( U_{i}^{n} -U_{i-1}^{n}\right) +0.003*r\left( U_{i+1}^{n} -2U_{i}^{n} +U_{i-1}^{n}\right)
\end{array}
OK, nice. So the left-hand side creates the matrix A and the right hand side created the vector b. Can you show now how to construct a row in matrix A and vector b? So what does the first and second row look like for instance?
row 1: $$[A_{11} A_{21} ... A_{N1}] \cdot U_1 = b_1$$
Yes, that what it should looks like
But what are the exact values in your case for the A's and the b's?
b is RHS and A should be the factors a,b and c that I forgot to replace them in this experssion
There is a minus sign wrong in your RHS.
But the big problem is the definition of the matrix A. What are the coefficients that belong to [itex]U_i[/itex], [itex]U_{i+1}[/itex] and [itex]U_{i-1}[/itex]?
Specifically, what do you do with the nonlinear term
[itex]-r*\Delta x*U_{i}^{n+1}\left( U_{i}^{n+1} -U_{i-1}^{n+1}\right)[/itex]
the nonlinear terms comes from the nonlinear PDE, and that what I got from Crank-Nicolson method
The point is that for interior points the Crank-Nicholson method reduces to [tex] U_i^{n+1} - \tfrac12\Delta t f_i(U^{n+1}) = U_i^{n} + \tfrac12\Delta t f_i(U^{n})[/tex] where [itex]f_i = \frac{\partial U_i}{\partial t}[/itex]. If [itex]f[/itex] is non-linear, then you don't get a matrix equation; you get a non-linear algebraic system [tex] F_i(U^{n+1}) = U_i^{n} + \tfrac12\Delta t f_i(U^{n})[/tex] which has to be solved by, for example, Newton's method.
Exactly. So at this point you have to decide what to do with the nonlinear terms. Most common is to linearize it and use a fixed point iterator (simplest) or Newton's method (better). Then, instead of solving Au=b for u, you start with an estimate for u, and substitute it in the function [itex]F(u)=A(u)\cdot u -b(u)[/itex] (A(u) is now depending on u) and you try to find u that minimizes F.
