Crate being pushed varying force
  • Thread starter Thread starter the.flea
    Force
The problem involves a 170 kg crate hanging from a rope of length 15 m, which is pushed horizontally with a varying force while moving 5 m sideways. Participants are exploring the magnitude of the force required when the crate reaches its final position, the total work done on the crate, and the work done by the rope's tension during the displacement.
  • Mixed
  • Participants discuss the calculations for the force and tension components, questioning the relationship between gravitational force and the applied force.
  • Some participants express uncertainty about calculating the work done by the varying force and how it relates to potential energy.
  • There are inquiries about the implications of the work done by tension being zero due to its perpendicular relationship with displacement.
  • Several participants attempt to clarify the definitions and calculations for work done by the applied force and gravitational work.
The discussion is ongoing, with various interpretations and calculations being explored. Some participants have provided insights into the relationships between forces and work, while others are still seeking clarity on how to calculate the work done by the applied force.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. The presence of a varying force adds complexity to the calculations being discussed.
the.flea
given/known data
A 170 kg crate hangs from end of rope length L = 15 m. You push horizontally on crate with varying force F to move distance d = 5 m sideways. (a) What magnitude be of F when crate is in final position? During crate's displacement, what are (b) the total work done on it, and (c) the work done by the pull on the crate from the rope?
Relevant equations
Fnet=ma
[tex]\Delta[/tex]K=Wnet=Wa+Wg+Wt
Wg=mgdcos180=-mgd
attempt at a solution
(a) F-(Tension in x component)/170 = 0 ---> F=1666/tan(cos[tex]^{}-1[/tex](5/15))=589
(b)0=Wa+Wg+Wt --->? Wa, i am not sure how to calculate as it is a varying force
(c)Wt= [tex]\Delta[/tex]K=0
how would this be proved numerically?
Basically what i need help with is calculating Wa. Any help is appreciated. Thanks.
Fnet=ma
Wg=mgdcos180=-mgd
3. The Attempt at a Solution
For a) why isn't the component of Force along x = M*g*Sinθ ?
For b) what do you know about the relationship between potential energy and work.
For c) Work is given by distance times the force acting along the path of that distance. Since at all points any Force from Tension is at right angles ...
for (a) gravity does not have any components. i think you misread the question. I've attached a diagram.
for (b) since the change in kinetic energy is zero, mgh is equal to the negative of work
for (c) i don't quite understand
(a) I can't view the attachment till it's approved, but I'm pretty sure that we can safely say that when the mass is pulled sideways ie. the string is not vertical, then force due to will have an x and y component.
(b) I agree there.
(c) I think he's saying that you can calculate the work done in each plane, and because they are at right angles to each other you can use pythagoras to find the work done by the rope (when the rope moves from vertical it has components in both directions).
so for a, are the calculations correct? tension will have its corresponding components, yes.
and for c work due to tension is always 0 then (cos90)
"why isn't the component of Force along x = M*g*Sinθ" how did you come to that conclusion?
EDIT: how would one calculate the Wa without setting it to negative work of gravity? it is a varying force
For A, you got 589 right? This is the x component of tension only. You need to calculate the net (pythagoras)
I'll look at C in a sec
EDIT: Hang on, sorry, you are right.
What are you defining Wa?
When LowlyPion said why isn't it mgsin(theta) he was simply taking theta to be on the other corner of the triangle.
Why is the work due to tension always 0?
Wa is the work done by the applied force.
since at any point on the rope it is right angles to displacement cos90=0 so then tcos90=0. the answer in the book is 0 too.
thats what i think.
thats what i think.
That is "Wa is the work done by the applied force ...and its magnitude is the scalar product of that force along the direction of its application.
Cos90 = 0 => Work from T is 0 You are correct.
For a) my apologies. I was thinking about another part of the problem and hurriedly proceeded to mislead by writing Sin instead of Tan. Sorry.
but since it is a varying force, how would i use the scalar product, it isn't a constant force. should i only apply it to the final position where. what is the formula for Wa? since its the negative of Wg= mghcos180=-(9.8)(170)(0.86)=-1429 J. Wa should be +1429J but how can i calculate it. Thanks for the help.
For b) what is the change in potential energy?
mg(df-di)=(9.8)(170)(14.14-15)=-1432.76J ? same as above i already calculated it?
How did you calculate the 14.14?
since it gets pushed sideways, the height changes vertically but the length of the rope remains the same. sqrt(15^2-5^2)=14.14
Cos19.47 was what I was expecting to see. .86 is fine.
ok so we have the change in potentila energy = Wg but what are the calculations or formula for calculating Wa. that is what i need to understand. thnks
It is the change in potential energy.
it all makes sense now. thanks for the help.
11K
