Cross product and dot product scalars
The discussion revolves around the calculation of the dot product and cross product of two vectors, d1 and d2, defined in a three-dimensional space. The original poster seeks clarification on how to express the result of their calculations as a scalar.
  • Participants discuss the correct interpretation of the dot product as a scalar and question the original poster's calculations. There are attempts to clarify the steps involved in computing the cross product and dot product.
The conversation is ongoing, with participants providing feedback on calculations and encouraging the original poster to share their work for better guidance. There is a recognition of errors in previous calculations, and some participants are exploring the implications of these errors.
Some participants note discrepancies in the calculations, particularly regarding the addition of vector components and the results of the cross product. There is an acknowledgment of the need for clarity in expressing the final scalar result for online submission.
TS656577
If d1 = 4i - 10j + 2k and d2 = 9i - 10j + 6k, then what is (d1 + d2) · (d1 × 4d2)?
Know how to do the cross product and dot product
For the answer i got 9.6i + 56j -127.68k. How do i express that as a scalar for an online program that only has one box to type in?
Your answer should be a scalar anyway if you had to take the dot product (commonly known as the scalar product). I suggest you check your answer.
I didnt think my answer was wrong though?
If you take the dot product of two vectors then the answer will be a scalar not a vector. If you post what you've done it'll be easier to identify where you went wrong.
First i calculated the quantity of d1+d2 and got 13i + 0j +8k. Then i went to the other side of the problem and distributed the 4 to the d2 terms and got a result of 36i - 40j + 24k. After that, i took the cross product of d1 and 4d2 and got -160i -24j - 200k. Then i took the dot product and got -2080i - 1600k (sorry i posted the wrong answer the first time, my bad)
For the addition of d1 and d2, -10 +(-10) does not equal 0.
For the cross product, that should be +200k.
The dot product of two vectors is:
[tex]\mathbf{a}\cdot \mathbf{b} = a_x b_x + a_y b_y + a_z b_z[/tex]
so then when i add that up, it equals one number? for example if i had axbx=3, ayby=4 and azbz=2, then i would have something that resembles 3+4+2 and would i use 9 for the answer?
yes, that's correct.
i got -3200 for my final answer, but that seems wrong..
Again if you post exactly what you've done when computing the dot product it will be easier to advise you where you went wrong.
after doing the cross product for d1xd2, i got -160i -24j -200k. After that, i multiplied by the sum i got for the d1+d2 section. So in the end, i multiplied -160 times 13, -24 times -20, and -200 times 8. Then i had -2080 + 480 - 1600
If you look in my previous post I said that after the cross product you should have +200k not -200k.
remeber that the cross product is something like;
[-,-]: VxV----->V; \\ V=vector space
so gives you back another vector;
while the dot product (generally an inner product) is something like;
(-,-): VxV------>C \\ C=complex field
know how to make both in an euclidean orthonormal basis and you'll get your answer;
regards;
marco;
got it, thanks guys...sorry for bein dumb (sick last few days)
  • · Replies 23 ·
  • · Replies 19 ·
