How Does Changing Load Capacitance Values Affect Crystal Oscillator Performance?
Changing load capacitance values affects crystal oscillator performance by altering the resonant frequency and efficiency of the oscillator circuit. Using a crystal with a lower load capacitance than recommended can lead to a slight decrease in the parallel resonant frequency and overall effectiveness as a resonator. While the basic operation of the IC oscillator circuit remains largely unchanged, increasing load capacitance can lower frequency and efficiency, potentially halting oscillation. Crystals operate primarily as series resonant devices, and when used in parallel resonance, the losses are transformed, impacting the circuit's performance. Ultimately, careful consideration of load capacitance is crucial for optimal oscillator functionality.
likephysics
How does the load capacitance affect the Crystal.
For example, IC manufacturers recommend a Crystal and also load capacitance, like 25MHZ, 16pF.
What happens if I choose a xtal with load cap of 10pF 25MHz?
I am talking about changing the load caps recommended by IC manufacturer, not the ones in xtal datasheets.Does the load cap value affect the amplifier ckt inside the IC?
The crystals with 16pF might have been intended for circuits using series resonant operation and those with 25pF for parallel. But it should not change the operation of the circuit very much and both are just pieces of Quartz.
Increasing the load capacitance lowers the parallel resonant frequency very slightly and also slightly reduces the effectiveness of the crystal as a resonator. It does not alter the basic operation of the IC oscillator circuit apart from lowering frequency and efficiency and eventually stopping oscillation.
This happens because a crystal is really a series resonant device. In many applications, however, a parallel resonance is created where the crystal is used slightly HF of its series resonant frequency to create a large inductive reactance. This then forms a parallel resonant circuit with the shunt capacitance. The losses of a crystal are physically part of the series resonant circuit, so when we use a parallel resonance, this loss resistance is transformed up by a factor Q^2 and appears as a very high resistance shunting the crystal. If we add shunt capacitance, the inductance of the crystal must be reduced, so Q (series) becomes less. If the Q of the series resoance is lowered, the shunt resistance, which depends on Q^2, is less.
Likes berkeman
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 30 ·
