Cube with charges at each vertex
archaic
Determine an expression for the magnitude of the electric field at the center of any face of the cube.
$$E=k\frac{q}{r^2}$$
Diagram of a cube with a charge q at each of its eight vertices, edges labelled s, with x, y and z axes drawn from one corner.
For convenience, I take the center of the upper face.
The charges at the top cancel each other's effects, and those at the bottom cancel each other's horizontal effects, so I get$$E=4k\frac{q}{r^2}\sin\theta$$I have found that ##\theta=\arcsin\left(\frac{s}{r}\right)=\arcsin{\sqrt\frac{2}{3}}##, with ##r=\sqrt{\frac{3}{2}}s##:$$E=4\frac{2}{3}\sqrt\frac23k\frac{q}{s^2}=\frac{8\sqrt6}{9}k\frac{q}{s^2}$$
Correct, right?
The method looks right, but I think you have dropped a factor of ##\sqrt{2}## in your very final answer.
should have been ##\sqrt6## instead of ##\sqrt3##. thanks, corrected!
