Curl H outside a long, thin wire of constant current
rude man
Insights Author
Per Maxwell's equation and my H. H. Skilling EM textbook, curl H = 0 in the absence of current density.
But consider a long, thin wire along the z axis carrying time-invariant current I. By Ampere's law, at a point (x,0) outside the wire, H = I/2πx j . But curl H computed by Cramer's rule from the curl determinant is not zero.
2. Relevant equations
curl H = J + ∂D /∂t
2πxH = I
Since I is time-invariant there is no time-varying electric field so ∂D/∂t = 0.
Since H = H j = I/2πx j at (x,0),
curl H = ∂H/∂x k - ∂H/∂z i
but for a long wire, ∂H/∂z = 0 so we wind up with
curl H = dH/dx k
= -I/2π x2 k ≠ 0.
So how is the paradox resolved, please? If you're familiar with the concept of little "paddle wheels" (Skilling uses) indicating curl, even there it seems curl H ≠ 0 outside the wire.
All glory and thanks to the resolver!
If you want to work in Cartesian coordinates, then first work out the general expression for the components of H in terms of x and y. Since you are going to take derivatives, you don't want to let y = 0 until after taking the derivatives.
Thanks, T. Will explore! I had a faint idea I shouldn't ignore the x component of H but never paid it enough attention.
I switched to cylindrical coordinates, and lo & behold ... :smile:
I won't bother with the cartesian but obviously am now a Believer! Thanks again, will get to sleep a bit faster now ...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
