Current and Voltage in a transformer
9 replies · 3K views · last reply
btpolk
The primary coil in a transformer has a power of 100W. The flux through a single loop in the primary is changing at a rate of 25 Wb/s. The primary has 100 loops and the secondary has 500 loops. Assuming a perfect transformer (no losses), determine the current and voltage in both the primary and secondary.
V1/V2=N1/N2=I2/I1
V1/V2=1/5→5V1=V2
I1/I2=5→5I2=I1
I have no knowledge of an equation/relationship between Wb/s and the other variables in this problems nor can I find one. Please Help.
A hint can be found in the units: A Weber (Wb) has the equivalent units of V*s (that is, one Weber is a Volt-second).
Given the rate of change 25 Wb/s for a single loop, what's the voltage on the primary?
Sorry, I don't understand your response. Your given information states that there is 100W associated with the primary. What's this 2500W you're proposing? Or do you mean 2500V? That would be a reasonable value :smile:
So, if the voltage on the primary is 2500V, what's the current?
Sorry, I did mean 2500V.
So to find the current I would use
P=V1I1
which would mean that the current would have to equal 1/25 A
P=V1I1
Yes. Now, how will you find the secondary voltage and current?
btpolk said:
5V1=V2
V2=12500V
P=I2V2
I2=1/125 A
Is that right?
Your results look good.
