The discussion centers on the current carrying capacity of copper busbars in aircraft, particularly at high altitudes. It is established that the thermal conductivity of pure copper is approximately 400 W/mK, while copper oxide (CuO) has a significantly lower thermal conductivity of 20 to 80 W/mK. The presence of a thin oxide layer on copper can increase emissivity, enhancing heat dissipation through radiation, especially at altitudes where convective cooling is less effective due to lower air density. The conversation also highlights that while copper is preferred for its conductivity, aluminum is often used in aircraft wiring for weight reduction.
- Understanding of thermal conductivity and emissivity in materials
- Knowledge of the effects of altitude on air density and heat transfer
- Familiarity with electrical properties of copper and aluminum
- Basic principles of convection and radiation heat transfer
- Research the thermal conductivity differences between copper and copper oxide
- Learn about the emissivity of various materials and its impact on heat dissipation
- Investigate the effects of altitude on electrical systems in aircraft
- Explore the advantages of aluminum versus copper in aerospace applications
Aerospace engineers, electrical engineers, and professionals involved in aircraft design and maintenance will benefit from this discussion, particularly those focusing on thermal management and material selection for electrical components.
