Current direction in a falling magnet through a wire loop
3 replies · 6K views · last reply
Feodalherren
A bar magnet is held above the center of a wire loop lying in the horizontal plane, as shown in the figure below. The south end of the magnet is toward the loop. After the magnet is dropped, what is true of the current in the resistor as viewed from above? (Select all that apply.)
Diagram of a bar magnet above a horizontal wire loop, with N at the top of the magnet and S at the bottom, a downward arrow labelled v beside it, and a resistor R in the loop.
It is counterclockwise as the magnet falls toward the loop.
It is clockwise as the magnet falls toward the loop.
It is always clockwise.
It is clockwise after the magnet has moved through the loop and moves away from it.
It is first counterclockwise as the magnet approaches the loop and then clockwise after it has passed through the loop.
Lenz's law and Faraday's Law
This is my conceptual picture of what's going on.
Two top-down diagrams with three circles each marked with a dot, labeled B and Going in or Falling out, plus side views of a bar magnet with N and S poles surrounded by green loops.
As the magnet is falling in the field lines are going N to S as always. So Just at the moment when the bottom of the South pole of the magnets hits the area inside the circle the field lines are coming toward us (as viewed from the top). As the magnet falls through and the N side is facing us, the field lines are again, coming toward us.
In both cases the current will be induced in such a way that the magnetic flux through the surface is constant. So it seems to me that it should flow clockwise in both cases. This is, however, incorrect. Where am I going wrong?
The induced emf is proportional to the change in (i.e., time derivative of) the magnetic flux, not to the magnetic flux itself.
Yes, that is what my pictures are trying to illustrate.
So how is the flux changing when the magnet falls into the loop? How is it changing when it falls out of the loop?
