Current in wire loop inside a solenoid
The discussion revolves around calculating the magnetic field inside a solenoid and its relationship to the current flowing through it. Participants emphasize the importance of applying Faraday's law and understanding how the magnetic field (B-field) relates to the current (I) in the solenoid. There is clarification on how to treat the current as it changes over time, with the formula dB/dt = μ₀*n*(dI/dt) being highlighted. Questions arise about the behavior of a larger loop surrounding the solenoid, particularly regarding the magnetic field and induced current in that loop. The consensus is that while the area of the loop changes, the magnetic flux remains significant even if the loop is larger than the solenoid.
gills
A 2.1m -long solenoid is 13.0cm in diameter and consists of 2200 turns of wire. The current in the solenoid is increasing at the rate of 1.0 kA/s .
Any help to point me in the right direction would be great.
I'm thinking that i need to find the magnetic field inside that of a larger solenoid. Then i somehow manage to put that into faradays law equation.
bump^^
That is exactly what you have to do. Good thinking.
HINT: How can you relate the current in the solenoid to the B-Field produced?
how do i treat the current since it is given per unit time? That is throwing me off.
B(solenoid) = \mu_{0}*n*I ---> ??
ok this is what I've got
dB/dt = \mu_{0}*n*\frac{dI}{dt}
ok, got the first part.
What about when there's a loop that is larger than the solenoid? Would the current in that loop be zero since the magnetic field outside of solenoid is almost neglible?
The diameter of the larger loop is 19.5cm
ok, nevermind on that one. Would i just be changing the area of the loop from the equation i derived in the first problem or is there more to it?
Yes, the only difference when the loop is bigger than the solenoid is the area of the loop. (The magnetic flux still goes through the loop if it's bigger than the solenoid.)
Keep working at it, you seem to be making some nice progress on this problem. Keep it up!:approve: If you have any more questions I'll answer them as soon as I can.
