Current through source in AC circuit with R & LC in parallel
2 replies · 3K views
Shivang kohlii
In the circuit diagram shown , Xc = 100 ohm , XL = 200 ohm , R = 100 ohm , the effective current through the source is ?
Z= √( R^2 + ( XL - Xc)^2)
Vrms = Irms/ Z
I tried to draw the phaser diagram and calculate the relation between the current in the LC branch and current in R branch( the phaser diagram is given as attachment)
From it I concluded that Inet = √( (I1)^2 + (I2)^2)
Where I1 = current through R branch
I2 = current through LC branch
And I got ans= 2√2 which is correct
1.What I am confused is that was my answer just by chance
2.And is it even possible to draw phaser diagrams when in parallel.. if yes, then is my attempt correct ?
3.If not , how else can we solve it .. or is there any easier method to solve it?
on Phys.org
In relation to applied voltage, what is the phase angle of current thru a:
Resistor?
Capacitor?
Inductor?
I think your answer (and the associated reasoning) is correct but it can't be solved in a simpler way.
We know that when we have elements in parallel the total impedance is computed in a similar way like when we have resistances in parallel.
In this circuit it would be $$\frac{1}{Z}=\frac{1}{Z_R}+\frac{1}{Z_{L+C}} \text{(1)}$$ where ##Z## is the total impedance of the circuit and ##Z_{L+C}## is the total impedance of the branch that contains the L and C. Because L and C are in series it is ##Z_{L+C}=Z_L+Z_C=i{(X_L-X_C)}=i100 Ohm##
Also ##Z_R=R=100Ohm##
So by (1) you can calculate ##Z##, and then calculate ##I_{rms}=V_{rms}/|Z|##
