Current = Voltage/Resistance or Power/Voltage?
  • Context: Undergrad
  • Thread starter Thread starter Sweeney
    Current
The discussion centers on the interpretation of electrical power calculations involving a local power station supplying 2 MW at 10 kV to an industrial park. Participants clarify that the total resistance of the cables, calculated using resistivity and dimensions, is essential for determining current flow. The confusion arises from whether to use the formula I = V/R or P/V, with the consensus that the latter accounts for power losses in the cables. The 10 kV represents the voltage at the power station, while the 2 MW is the net power delivered to the load after losses.
  • Understanding of Ohm's Law (I = V/R)
  • Knowledge of power calculations (P = V * I)
  • Familiarity with electrical resistivity and its impact on current flow
  • Basic concepts of power loss in electrical systems
  • Calculate the total resistance of cables using resistivity and dimensions
  • Learn about power loss in transmission lines and methods to reduce it
  • Explore the implications of voltage drop in electrical systems
  • Investigate the differences between apparent power and real power in AC circuits
Electrical engineers, students studying power systems, and professionals involved in energy distribution and efficiency optimization will benefit from this discussion.
Sweeney
I was doing (ii) in the following question.
The ESB supplies electrical energy at a rate of 2 MW to an industrial park from a local power station, whose
output voltage is 10 kV. The total length of the cables connecting the industrial park to the power station is
15 km. The cables have a diameter of 10 mm and are made from a material of resistivity 5.0 × 10–8 Ω m.
Calculate
(i) the total resistance of the cables; (15)
(ii) the current flowing in the cables; (6)
(iii) the rate at which energy is “lost” in the cables. (6)
Suggest a method of reducing the energy “lost” in the cables. (5)
When trying to work out current I used V/R but from the marking scheme I found out that the right (and different) answer is obtained by using P/V. Are these two formula not equivalent? If not, what is different about them?
The two formulas are the same, but perhaps the difference is in how you base your calculations since the power supplied by the source is not the same as the power received by the load, due to the loss in the lines.
If you want to calculate the current in the cables, you can use I=V/R but you need the voltage drop on the cables. Which is not given. The 10kV is not the voltage drop on the cables but the total voltage at the output of the local power station.
Similarly, 2MW is the power used by the industrial park, not what is lost in the wires.
I thin that 2MW is the total power delivered (supplied). And 10 kV is the voltage of the power station, as it says in the text.
Part of this voltage drops on the wires, resulting in some power being dissipated on the same wires.
But to find the current you don't need to know how is the power distributed, do you?
One of us is reading the problem incorrectly. The way I read it, the problem specifically says the 2MW is delivered to the load. It does NOT say that the 2MW is the power produced by the station although I certainly see how you can read it that way.
The problem is badly stated and the OP has to go with whatever interpretation gives him the right answer, since he seems to know the answer.
So you would take it that the 10kV is the output of the power station (before cables) - this is explicitly given. The 10kV is the output of the power station.
But the 2 MW power is after the cables, at the input of the industrial park.
It makes sense if "supplied" means the net power entering the industrial park rather than what "leaves" the power station.
However I don't see how can you say that one interpretation is "incorrect", based just on the text
Unless you have some inside info about what the author have in mind.:smile:
I said that ONE OF US is reading the problem incorrectly. I do not presume to say which one. They are both interpretations. Was that not clear from my post?
Yes, I understand this. I did not try to defend my "reading". Actually, thinking about real world, we pay directly the energy delivered to the house. The energy lost in cables comes into fees and surcharges (which we pay as well). So your reading would be more likely.
It's just the way you said that one of us is reading it incorrectly. I don't think that the fact we read it in two different ways would necessarily makes one "incorrect". As long as the text is formulated such that multiple interpretations are possible, they may all be "correct". Only extra information can provide a criterion to decide otherwise. They may be both wrong, after all.:smile:
Best show your working so we can see where you went wrong.
It's surprising how many people use the "line voltage" instead of the "voltage drop down the line" to calculate the power loss.
That would be my reading but I agree the question isn't clear.
In most cases it's the load (the industrial park) that determines how much power is consumed. The power station just delivers whatever is required to maintain a 10kV output.
  • · Replies 20 ·
  • · Replies 57 ·
13K
