MHB Cut 16" Pizza into 3 Equal Pieces Using Calculus
  • Thread starter Thread starter MarkFL
    Cutting
MarkFL
MHB
Here is the question:
How do you cut a 16 inch diameter pizza into 3 equal pieces using calculus?
It's a long one and someone told me 3pi/2 is the answer...I really need to know how to get that. Are there any similar problems on the internet I can follow to this one also?
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Topher L,
One way to cut the pizza into 3 equal pieces is to make 3 radial cuts to divide the pizza into 3 equal sectors each subtending an angle of $$\frac{2\pi}{3}$$. We simply divide the complete circle's angle of $2\pi$ by 3.
However, since you state that calculus is to be used, I suspect we are to make 2 parallel cuts along chords of the circle. So, if we orient the circle with its center at the origin of our $xy$-coordinate axes, we may cut along the lines $x=\pm c$. To find the value of $c$, we may state (where $r$ is the radius of the circle):
$$\int_0^c \sqrt{r^2-x^2}\,dx=\frac{\pi r^2}{12}$$
If we let:
$$x=r\sin(\theta)\,\therefore\,dx=r\cos(\theta)$$
We obtain:
$$r^2\int_0^{\sin^{-1}\left(\frac{c}{r} \right)} \cos^2(\theta)\,d\theta=\frac{\pi r^2}{12}$$
Using a double-angle identity for cosine, we may write:
$$\frac{r^2}{4}\int_0^{\sin^{-1}\left(\frac{c}{r} \right)} 1+\cos(2\theta)\,2\,d\theta=\frac{\pi r^2}{12}$$
Let $u=2\theta\,\therefore\,du=2\,d\theta$ and we have:
$$\frac{r^2}{4}\int_0^{2\sin^{-1}\left(\frac{c}{r} \right)} 1+\cos(u)\,du=\frac{\pi r^2}{12}$$
Using the anti-derivative and the FTOC, there results:
$$\frac{r^2}{4}\left[u+\sin(u) \right]_0^{2\sin^{-1}\left(\frac{c}{r} \right)}=\frac{\pi r^2}{12}$$
$$\frac{r^2}{4}\left(2\sin^{-1}\left(\frac{c}{r} \right)+\sin\left(2\sin^{-1}\left(\frac{c}{r} \right) \right) \right)=\frac{\pi r^2}{12}$$
Multiply through by $$\frac{12}{r^2}$$:
$$3\left(2\sin^{-1}\left(\frac{c}{r} \right)+\sin\left(2\sin^{-1}\left(\frac{c}{r} \right) \right) \right)=\pi$$
Using the double-angle identity for sine, we have:
$$6\left(\sin^{-1}\left(\frac{c}{r} \right)+\sin\left(\sin^{-1}\left(\frac{c}{r} \right) \right) \cos\left(\sin^{-1}\left(\frac{c}{r} \right) \right) \right)=\pi$$
$$6\left(\sin^{-1}\left(\frac{c}{r} \right)+\frac{c\sqrt{r^2-c^2}}{r^2} \right)=\pi$$
We may arrange this as:
$$f(c)=6\left(\sin^{-1}\left(\frac{c}{r} \right)+\frac{c\sqrt{r^2-c^2}}{r^2} \right)-\pi=0$$
Without loss of generality, we may let the radius of the circle be 1 unit:
$$f(c)=6\left(\sin^{-1}(c)+c\sqrt{1-c^2} \right)-\pi=0$$
Using a numeric root-finding technique, we find:
$$c\approx0.264932084602777$$
Since the radius of the pizza in the given problem is 8 inches, we then find that the cuts should be made along the lines:
$$c\approx\pm2.119456676822216$$
At one point, you suddenly replaced c with sin^-1 (c/r). Can you explain why you did that?
Yes, I did so in accordance with the substitution I made. Let's go back to this point:
Now, we next used the substitution:
Now, originally the limits of integration are in terms of $x$, but we now want them to be in terms of the new variable $\theta$, and we find that:
$$x=r\sin(\theta)$$
May be solved for $\theta$ by dividing through by $r$ and arranging as:
$$\sin(\theta)=\frac{x}{r}$$
And this implies that we may write $\theta$ as a function of $x$ as follows:
$$\theta(x)=\sin^{-1}\left(\frac{x}{r} \right)$$
Hence, we find:
$$\theta(0)=\sin^{-1}\left(\frac{0}{r} \right)=0$$
$$\theta(c)=\sin^{-1}\left(\frac{c}{r} \right)$$
And these are our limits in terms of $\theta$, allowing us the write the definite integral as:
$$r^2\int_0^{\sin^{-1}\left(\frac{c}{r} \right)} \cos^2(\theta)\,d\theta$$
Does this make sense?
This makes perfect sense, thank you.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
