Cylinder lying on conveyor belt
78 replies · 13K views
JD_PM
You buy a bottle of water in the store and place it on the conveyor belt with the longitudinal axis perpendicular to the direction of movement of the belt. Initially, both the belt and the bottle are at rest. We can approach the bottle as one cylinder with radius ##R##, mass ##M## and moment of inertia ##I = M R^2##, in which the mass is not distributed uniformly. The speed of the belt at time ##t## is ##V (t)##.
a) Find an expression for the speed ##v(t)## of the centre of mass of the bottle.
Second Newton's Law for rotation:
$$\tau = I \alpha = Rf$$
I got two expression for the speed of the centre of mass of the bottle, and I wanted to know if both are equivalent and correct.[/B]
Using the second Newton's Law for rotation you end up with the expression:
EQ1:
$$R\alpha=2a_0$$
Additionally, the total acceleration is the sum of the tangential and centripetal vector components of the acceleration. Thus:
EQ2:
$$a = a_o + R\alpha$$
With this info we can deduce that:
EQ3:
$$a_0=\frac13 a$$
EQ4:
$$R\alpha=\frac23 a$$
EQ5:
$$f=\frac13 Ma$$
Therefore, using the second Newton's Law for rotation I got the following speed:
EQ6:
$$v_{CM} = \frac{3R \omega}{2}$$
And using kinematics:
$$v_f^2 = v_o^2 + 2a(x_f - x_o)$$
I got:
$$v_{CM} = \sqrt{ \frac{6fd}{M}}$$
Note that ##d## is the distance the rolling cylinder covers.
Are these correct and equivalent?
Thank you
This statement is problematic. If the cylinder has radius ##R## and the moment of inertia about its axis is ##I = M R^2##, then all the mass must be at radius ##R##. If in addition the distribution is non-uniform, it can only depend on the angle. The velocity of the cylinder ##v(t)## will have to depend on the angular distribution of the mass and that is not given.
Setting that aside and assuming that the moment of inertia is just ##I## and the mass distribution has no angular dependence, it seems to me that since the velocity of the belt is given as ##V(t)##, the answer to the problem must have it on the right hand side. You should not assume that the acceleration of the belt is constant.
These components are perpendicular to each other. You cannot add them as scalars. You need to rethink the problem. Imagine the belt starting from rest moving with velocity ##V(t)## and acceleration ##\frac{dV}{dt}##. What is the instantaneous velocity of the point on the cylinder that is in contact with the belt?
First, unless the water is frozen things will get very complicated, so let's assume it is.
Second, are you sure it doesn't say I≠MR2? Or maybe I≠½MR2?
EQ1:
$$R\alpha=2a_0$$
EQ2:
I assume you are defining a0 as the acceleration of the centre of the cylinder.
Your eq 1 seems to be assuming I=½MR2, which is not the case here.
You don't mean centripetal acceleration here. It looks like you are defining a as the linear acceleration of the point of the cylinder in contact with the belt, so your eqn 2 is just adding an acceleration to a relative acceleration in the same direction. But be careful with signs. Which way will the cylinder be rotating in relation to its forward movement?
The equation you quote is only valid for constant acceleration. As @kuruman points out, you should not assume that.
Yeah I have been suggested before about the fact that ##V(t)## should appear on my ##v_{CM}## equation. This is because the motion of a rolling object is the combination of the translation and rotation! My bad.
This is what I think it happens:
So the translational velocity of the centre of mass is:
$$v_{CM} = \frac{3R \omega}{2} + V(t)$$
I do not understand why both you and haruspex suggested that.
##V(t)##
Literally says: '...We can approach the bottle as one cylinder with radius ##a##, mass ##M## and moment of inertia ##I = M k^2## (##k## in units of length), in which the mass is not distributed uniformly...'
Absolutely, my bad! Actually, it is:
$$R\alpha=a_0$$
NOTE: I will continue posting in a few...
Ok, that makes sense. k is not the radius of the cylinder, just some constant. I think it is called the radius of inertia.
Because you are not told it is constant. Instead, you are given that the speed is V=V(t), i.e. some unknown function of time.
The equation you quoted under "and using kinematics" is only valid for constant acceleration. (And by the way, you mean kinetics, not kinematics.)
I've heard it called the radius of gyration.
JD_PM said:
##V(t)##
Yes, I think it is safe to assume that the points of contact are at rest with respect to each other, i.e. kinetic friction does not play a role here. Now pretend that you are sitting on a chair placed on the belt, in other words transform to moving belt's frame. The belt is at rest relative to you and so are (instantaneously) the points on the cylinder that are in contact with the belt. Would you see the cylinder move? If so how would you analyze its motion in the belt's frame of reference? Once you do that, you can transform back to the room's frame of reference.
$$R\alpha=a_0$$
Back at it.
Thanks to the haruspex comment I highlighted on #9, I realized that my calculations were wrong because of the bad selection of moment of inertia equation. Corrections:
$$R\alpha=a_0$$
$$a_0=\frac12 a$$
$$R\alpha=\frac12 a$$
$$f=\frac12 Ma$$
$$v_{CM} = 2R \omega$$
Based on this, the speed ##v(t)## of the centre of mass of the bottle is:
$$v(t) = v_{CM} + V(t) = 2R \omega + V(t)$$
JD_PM said:
Back at it.
$$R\alpha=a_0$$
$$a_0=\frac12 a$$
$$f=\frac12 Ma$$
Now I am confused on the following:
I know that the translational speed of the centre of mass for pure rolling motion on a non moving floor and measured from an inertial reference frame is:
$$v_{CM} = \frac{ds}{dt} = R\omega$$
Where ##s## is the arc of the cylinder
But how is it possible that I get ##2R \omega## just with the difference that in this case the floor (belt) is moving?
OK you propose I am on a non inertial reference frame now. Yes, I would observe the cylinder rolling. The cylinder rolls because of the torque exerted by the external force of static friction on the cylinder. Actually, the cylinder would move in the opposite direction to that of the friction and in the same to that of the fictitious force F (as we are on a non inertial reference frame we have to add a reaction force F; the action force is clearly f).
Careful here. In the non-inertial frame, the belt is at rest, yet the cylinder accelerates. An observer in that frame deduces that there must be an external force acting on the cylinder. In what direction is that force, what is its magnitude and at what point on the cylinder is it applied?
Let's say the cylinder accelerates backwards. The external force exerted on the cylinder is the static friction ##f## ,which acts on the only point of contact with the belt, pointing backwards:
$$f = Ma_o$$
Where ##a_o## is the tangential acceleration.
But this is not the only force exerted on the system. There is a fictitious force ##F## acting on the COM of the system.
Here it is a picture of what is going on (there was a mistake in the attached image to this post, now fixing):
Please clarify what you mean by that. Why isn't f/M the linear acceleration of the cylinder, i.e. of its mass centre?
JD_PM said:
There is a fictitious force F acting on the COM of the system.
I don't know what to write here. I would not have taken you along a non-inertial path. Not sure what @kuruman has in mind.
On a non inertial frame of reference we have the following scenario:
Where ##F## is the fictitious force and ##f## is the static friction.
Though I am not sure, as I am wondering if they should be opposite instead...
Actually, after having some thoughts, I think F should point backwards and the friction force forwards. Thus the diagram flaws.
Ok, though I believe they would be inopposite directions, but that doesn't matter. If so, the sign will come out negative.
So what equations follow from that?
OK let's carry on with opposite directions. Using Newton's second law for translation we get:
$$-F + f = ma_o$$
$$a_o = \frac{-F + f}{m}$$
$$-F + f = ma_o$$
I assume you are now defining ao as the linear acceleration of the mass centre of the cylinder in the belt's reference frame.
Ok, so what about rotational acceleration.
OK before starting with rotation one question about signs. I think ##a_o## would be negative as ##F>f##... Does this mean that both forces should have the same direction instead?
Yes F will have a greater magnitude than f, but that just means the resulting observed acceleration is in the same direction as F,
OK I think that what happens is that ##a_o## has a negative sign as well, because is pointing backwards. Thus:
$$a_o = \frac{F - f}{m}$$
$$\tau = Rf$$
$$f = \frac{\tau}{R}$$
JD_PM said:
$$\tau = Rf$$
That does not mean anything unless you specify the axis.
What about the angular acceleration?
It looks like you are confused about action and reaction forces. Only action forces act on the system, here the cylinder. Reaction forces act on entities outside the system and are not part of the system's free body diagram. For example, the horizontal contact force of static friction acting on the cylinder has a reaction counterpart that is in the opposite horizontal direction and is part of the belt free body diagram, the action force of gravity ##m\vec g## acting on the cylinder has a reaction force ##-m\vec g## acting on the Earth, etc. etc.
I do not wish to detract @JD_PM from the current path. When this problem has been solved to everybody's satisfaction, perhaps I will post my solution for consideration.
Yes, I was reluctant to remain involved for the same reason, but we seem to be in different timezones and I did not want to leave the OP dangling. Anyway, it seems to me that the thread has since then stuck with the non-inertial view, so no need for you to hold back.
