Why Is Angular Momentum Not Conserved When a Cylinder Moves on a Stopping Board?
  • Thread starter Thread starter Mark128
    Board Cylinder
The discussion focuses on the conservation of angular momentum in a system involving a cylinder moving on a stopping board. The initial calculations using the moment of inertia formula, I = 0.5*m*r^2, and the angular momentum equations were found to be incorrect due to the influence of external forces, specifically friction. It is established that angular momentum can only be conserved about an axis where no external torques act, suggesting that using the point of contact between the cylinder and the board as the axis allows for conservation of angular momentum. This method avoids complications introduced by friction and provides a clearer path to solving the problem.
  • Understanding of angular momentum and its conservation principles
  • Familiarity with moment of inertia calculations, specifically I = 0.5*m*r^2
  • Knowledge of torque and its effects on rotational motion
  • Basic principles of friction and rolling contact dynamics
  • Study the effects of friction on angular momentum in rotational systems
  • Learn how to apply the principle of conservation of angular momentum about different axes
  • Explore the relationship between linear and angular momentum in systems with rolling motion
  • Investigate the use of non-inertial reference frames in analyzing motion
Physics students, mechanical engineers, and anyone studying dynamics and rotational motion will benefit from this discussion, particularly those interested in the nuances of angular momentum conservation in the presence of external forces.
Mark128
On the flat surface lays a flat board with mass M, and on the board - a cylinder with mass m and radius r. Initially, board moves with velocity v, and cylinder rotates with such angular velocity, that it's stationary relative to the ground. Because of friciton between the board and surface, the board stops after some time. What is velocity of cylinder after that happens?
I've been trying to solve it mainly through conservation of momentum and angular momentum, appareantly it's not correct. My idea was:
I, Moment of inertia = 0.5*m*r^2
L1, initial angular momentum = I * v/r
After a board stops, the change in it's momentum is M*v, so the impulse of torque on the cylinder will be M*v*r.
So the change in angular momentum is M*v*r.
So L2-0.5*m*r^2 = M*v*r
L2 = 0.5*m*r*v_final
So v_final = v*(0.5*m + M)/(0.5*m)
But as mentioned earlier, it's incorrect and I'm also not entirely sure which part is wrong.
You can only take angular momentum about some chosen axis to be conserved in a system if there are no external forces that have a torque about that axis. You appear to be taking the centre of the cylinder as axis, but there is friction (rolling contact) between the cylinder and the board.
What axis could you use to avoid this difficulty?
Yes, I was taking a center of the cylinder keeping in mind, that there is friction acting on it, and that's why change in angular momentum (L2-L1) is non-zero.
If I choose point of contact as center, the angular momentum is in fact conserved, but I don't know, how this could help.
There are two ways you can solve it:
1. Take moments about the cylinder’s centre, but include the torque from friction with the board and write a linear momentum equation also involving the friction. (You will have terms like ##\int F.dt##.)
2. Take moments about a point at the surface of the board. (Better not to think of it as a point fixed to the board or the point of contact over time since in principle that gets you into noninertial frames.) Since angular momentum of the cylinder is conserved about such a point you can get the answer in one equation.
  • · Replies 17 ·
16K
