Optimizing Battery Connections: A Scientific Approach
  • Thread starter Thread starter banoosh
    Cells Circuits
To achieve maximum voltage, the two "D" cells should be connected in series, resulting in a total voltage of 3 volts. For maximum power, connecting the cells in parallel is optimal, as it maintains the voltage while increasing current capacity. To prolong battery life, connecting the cells in series is preferable, as it reduces the current draw on each battery. The discussion also highlights the importance of understanding circuit configurations and their impact on voltage and power. Overall, the connection method significantly affects the performance and longevity of the batteries when powering a light bulb.
banoosh
Suppose you have two “D” cells and wish to use them to power a light bulb.
The two batteries can either be connected in series or in parallel.
(a) In order to achieve maximum voltage, how should the cells be connected? Explain.
(b) In order to achieve maximum power, how should the cells be connected? Explain.
(c) In order to last longest before going dead, how should the cells be connected? Explain.
(d) How many times longer will the cells last when connected this way versus the other? Explain.
P= IV
V= IR
Req= r1+r2+...
1/Req= 1/r1 + 1/r2 + ...
Having some trouble grappling with conceptuality here. how do the two types of series differ in functionality? i know what series and parallel circuits look like but not how they work. any help is appreciated
What is the equivalent voltage of two batteries of, say, 1.5 volts each connected in parallel?
What is the equivalent voltage of those same two batteries connected in series?
What circuit component represents the light bulb?
Can you draw a simple circuit diagram of those two configurations - batteries in parallel powering the bulb, and batteries in series powering the bulb?
banoosh said:
P= IV
V= IR
Try substituting to get an equation for P in terms of V and R.
  • · Replies 24 ·
