D.E. Linear equation with integrating factor
The discussion revolves around solving a first-order linear differential equation using an integrating factor. The original poster presents their work on the equation in the form y' - y = 7e^t + 56e^(8t) and attempts to find a solution while checking the initial condition y(0) = 2.
  • Exploratory, Assumption checking
  • The original poster outlines their method for finding the integrating factor and the solution, but questions whether their equation is in standard form. Other participants suggest verifying the solution by substituting it back into the original differential equation and checking the initial condition.
Participants have provided feedback on the original poster's solution, indicating that it appears correct. There is a focus on ensuring the solution format aligns with the requirements of the submission software, with suggestions to consider different notations for the exponential terms.
There is mention of potential issues with the submission software's acceptance of the solution format, prompting participants to explore whether specific notation or order of terms is required.
Marco Lugo
https://webwork.utpa.edu/webwork2_files/tmp/equations/2d/02a7e6a06f5b2424758fa01cc965f71.png with https://webwork.utpa.edu/webwork2_files/tmp/equations/80/81c176aa8964438a63eb096513245f1.png
[/B]
Standard form: y' + p(x)y = f(x)
Integrating factor: r(x)= e∫p(x)dx
Solution: y(x) = e-∫p(x)dx(∫e∫p(x)dx ⋅ f(x) dx + C)
From, y' - y = 7et + 56e8t
I got, p(x) = -1 and f(x) = 7et + 56e8t
So the integrating factor is r(t)= e∫-1 dt = e-t
Plug it into the solution formula,
y(t)= et [∫e-t (7et + 56e8t) dt + C]
= et (7t + 8e7t+ C)
= 7tet + 8e8t+ Cet
Using the initial condition y(0)= 2
= 8 + C = 2
C = -6
My final solution,
y(t) = 7tet + 8e8t- 6et
check: y(0) = 7(0)e(0) + 8e8(0)- 6e(0) = 2
But when I type it into WeBWork, it says my answer is incorrect. I don't think its a syntax problem because it has a preview button that allows you to see your actual problem.
Could it be that, y' - y = 7et + 56e8t is not in standard form?
[/B]
= et (7t + 8e7t+ C)
= 7tet + 8e8t+ Cet
= 8 + C = 2
C = -6
My final solution,
I don't see anything wrong with your work or your solution. You can (and should) verify for yourself that your solution is correct by first checking that the initial condition is satisfied, and then by substituting your solution into the differential equation. Your solution should make the DE a true statement.
As far as why the software doesn't accept your solution, make sure that you are working the same problem it thinks you are working. I would also check with the instructor.
I checked the initial condition but you're right I should have substituted my solution into the problem.
my solution,
y(t) = 7tet + 8e8t - 6et
check:
dy/dt= 64e8t + 7tet + et
substituting both into the initial probelm,
dy/dt - y = 56e8t + 7et
64e8t + 7tet + et - 7tet - 8e8t + 6et
I get, 56e8t + 7et
I don't see anything wrong. I would submit the answer again but I only have 2 more tries, so I want to get some more advice before I do.
my solution,
check:
I get, 56e8t + 7et
Your solution is correct.
Is there some special format you must adhere to when submitting solutions? For example, do you need to say exp(t) instead of et? Does it matter whether the terms come in a particular order, different from the one you wrote? For example, would ##8 e^{8t} + 7t e^{t} - 6e^{t}## or ##8 e^{8t} - 6 e^{t} + 7 t e^{t}## both be acceptable? Can you write ##t e^{t}## (or ##t \exp(t)##), or must it be in the form ##e^{t} \, t## (or ##\exp(t)\, t##), etc? I would certainly hope that the software would not be so picky, but who knows?
It worked! I had to use the exp(t) notation; which is weird because the software usually isn't picky and it would say if it wanted something expressed in a certain way.
Anyway thanks Mark44 and Ray Vickson for all you're help :D
  • · Replies 18 ·
