D.E. Reduction of Order: Can't integrate
16 replies · 2K views
oh yea. I need to divide everything by 6x^2. Thanks.
it still won't integrate..
By virtue of one solution being y = x^(1/2) you can say that x > 0.
So that |x| = x
If you remember how |x| is defined:
|x| = -x for x<0
|x| = x for x > 0
So going on that concept, are these two answers correct?
For 9: The actual integration is correct, however, your formula is wrong as you are multiplying by √2 instead of √x (y1).
Number 10 should be correct. Not quite sure how you deduced the integral was equal to x2sin(lnx) but it is correct.
Thanks. I fixed #9. For #10 I just used the Ti-nSpire CAS.
AH okay then. But for other integrals just make sure you can do them by hand if you ever need to.
Also when you are putting together your general solution, you can combine the constants so if you have y=c1x+25c2x2, you can rewrite it as y=c1x+c3x2.
What is the "largest interval of definition"? (0,inf)?
What are the steps you go through to answer that part of the question? You look in the denominator of every step to try to see if any x value would make the equation undefined? or do you just see if any x value would make the equation undefined for the final answer? or do you see if any x value would make the equation undefined for y1 and y2?
Yes, you would check to see where the function exists. The function will not exist for x=0 as seen in the solution of y2 and not exist if x < 0 as seen in y1 and y2.
ok. So to be specific, you only look at the y1 and y2 when checking where the function exists, not the any of the work done to get the solutions.
Basically.
