How do Dangerous Unstable Lakes pose a potential threat to human populations?
  • Thread starter Thread starter BillTre
Dangerous unstable lakes in Africa pose significant threats to human populations due to the potential release of large amounts of CO2 and methane from deep water layers. These lakes can maintain stable conditions for extended periods; however, disturbances such as volcanic activity or underwater landslides can trigger the release of gases, leading to suffocation hazards in surrounding areas. The use of airlift tubes, a simple technology familiar to aquarium hobbyists, can effectively reduce dissolved CO2 levels in these lakes, mitigating risks. Historical incidents highlight the urgency of addressing this phenomenon to protect vulnerable communities.
  • Understanding of limnology and lake chemistry
  • Familiarity with gas solubility principles, particularly CO2 and methane
  • Knowledge of environmental monitoring techniques
  • Basic principles of underwater pumping systems, such as airlift tubes
  • Research the mechanisms of gas release in stratified lakes
  • Explore case studies on the management of dangerous lakes in Africa
  • Investigate the design and operation of airlift pumping systems for environmental applications
  • Learn about the impact of volcanic activity on aquatic ecosystems
Environmental scientists, lake management professionals, public health officials, and anyone involved in disaster preparedness and response related to natural hazards.
BillTre
The African continent has several deep lakes with a deeper layer that is mostly not mixing with the overlaying layer. This could be due to a higher salinity, making the deeper layer more dense, and therefore stable.
If enough CO2 or methane is pumped into the lower layer of water, it may get close to its saturation point. Nevertheless this can be stable for long times.
However, if something disturbs the deep layer. Part of it may slosh around and moving some of it to a shallower area with less pressure. If gas starts bubbling out of solution, the water becomes less dense volume of water and rises toward. This will draw water from lower regions up under neath to where it will release gas and continue the cycle.
The initial disturbance could be any of a number of things: volcanic heating of deep layers, underwater land slide (maybe from an earthquake) disturbing enough of the deep layer to start the cycle. ?
Water can hold huge amounts of CO2, so really massive amounts can be released, enough to flood a valley with heavier than air CO2 and suffocating them.
This is known to have at least once, and is a potential threat to at least hundreds of thousands.
Using very simple technology, any aquarium hobbyist would be familiar with, an airlift tube, a self powered (once started) pump (the air lift tube), is used to pump saturated water from the bottom of one of these lakes.
The rate is easily controlled with a valve. Amount of dissolved CO2 levels were reduced safely.
Different lakes work differently because they have different chemistries going on. Different solutions.
Much of this and a lot more is in this nice Nature podcast written up as a little article.
Maybe the writer went to a meeting.
  • Wow
I’ve seen something of this on NOVA where heavy gases would get released and stream down a mountain and inundating villages or laying low in a depression until a small animal or child ventures in and can’t breathe.
There was one project that pumped out the trapped methane from a deep lake to prevent the buildup but I can’t remember where in Africa.
https://www.forbes.com/sites/davidb...angerous-volcanic-phenomenon/?sh=55f92fb1247b
Heres the NOVA link
  • Wow
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 19 ·
9K
  • · Replies 21 ·
11K
  • · Replies 19 ·
