Data transfer from MS Excel to PSPP
  • Thread starter Thread starter chwala
    Data Excel
16 replies · 5K views · last reply
chwala
Homework Statement:: See attached
Relevant Equations:: analysis stats
Find below a sample of the data that i want to import onto spss; My intention is to have the data appearing as one variable only on PSPP.
Excel spreadsheet screenshot with values in column G: row 1 shows 12 14, row 2 shows 12, row 3 shows 14 16 20, row 4 shows 34, row 5 shows 67, row 6 shows 20 22.
This is how it appears on PSPP;
Screenshot of the PSPP Variables view showing five numeric variables VAR001 to VAR005 with width 1 and decimals 0, above a Data Preview grid of mostly blank and numeric cells.
It defaults as 5 variables, ...i used comma delimited and i am aware that the pspp regards any comma/space as a variable i.e if you were to have for instance;{20 30 90} on one excel cell then importing this to pspp( using comma delimited ), yields 5 variables on pspp...which is not exactly what i want. I want the data on Ms excel to be imported onto spss as one variable only.
cheers...
That is not going to be easy using standard export/import routines. I can see two solutions:
  1. (better) generate data in Excel in a more consistent format
  2. (kludgy) write a simple search and replace script in [insert your favourite scripting language] to process the CSV file into the shape you want.
Cheers, the other option would be to have the multiple items appear as one item that is, instead of {a b c}, I would have my item appear as {abc} on excel...then import.
Unless you're trying to learn techniques to do the process, it seems data set is small enough you can just create it in SPSS by replicating the data there.
FWIW, if you're interested in learning how to scrape/import/export data, then data cleaning is where it's at. Most of the time you'll spent having to deal with mangled data, rather than with the design of models.
The actual data set has ##25,000## entries. The attached excel is just a dummy. I wanted help on duplicate entries that appear on a cell. Cheers.
FWIW, if you want to do something beyond
My bad. Let me think about it. Though it's an example of data cleaning.
Thanks @WWGD
Excel is the wrong tool for data cleaning.
Are you actually creating this data in Excel or are you reading it in from a CSV file? If the latter, please post (an extract from) the CSV file here. What tools do you have available: Python? Perl? Nothing but a web browser?
I have the raw data on an excel sheet and i need to import to pspp...i am converting using the csv format. The data is too large to be uploaded here. Kindly note that i was able to import the data and subsequently analysed the data. The only issue was as indicated on post 1. I have data appearing as indicated on excel sheet ...
check column G for e.g Row 1 has two entries { 12 & 14} as shown...on importing to pspp...it defaults as two variables [i.e variable 1 and variable 4 as shown on pspp] ...i want this to appear\default as one variable only hence the reason why i posted this query. I hope this helps ...
How did it get there? If you are generating it with formulae, just use different formulae. If you have uploaded it from a CSV file it would be easier to work with the original CSV file. If you have been sent the file as an xlsx file then it would probably best to save it as a CSV file. You can then use any decent text editor (e.g. Visual Studio Code) to replace all " " (space) characters with "\n\r" (otherwise known as CRLF). Or write a Python, Perl etc. script to do this.
pbuk said:
How did it get there? If you are generating it with formulae, just use different formulae. If you have uploaded it from a CSV file it would be easier to work with the original CSV file. If you have been sent the file as an xlsx file then it would probably best to save it as a CSV file. You can then use any decent text editor (e.g. Visual Studio Code) to replace all "," characters with "\n\r" (otherwise known as CRLF). Or write a Python, Perl etc. script to do this.
Ok thanks for the info...cheers @pbuk
Well, it does live there at the moment.
But it is trivially easy for Excel to export it in CSV format.
Where to? I mean, what else should be used?
Edit: or you could do it in a browser with some JavaScript like this that I just wrote:
Oh wait a minute, it's extra spaces you want to convert to CRLFs, not ","s. I've edited accordingly above.
