DE question involving a falling object
The discussion focuses on solving the first-order differential equation (DE) for the velocity of an object falling through the Earth's atmosphere, represented by the equation dv/dt = g - kv, where k is the drag constant and g is the gravitational constant. Participants provided insights on transforming the DE into a solvable form, emphasizing the use of integration factors and the separation of variables method. The general solution combines the homogeneous and particular solutions, and the initial condition v(0) = 0 is applied to find the specific solution. Additionally, the discussion addresses rewriting the velocity function in terms of terminal velocity, vT, leading to the equation v(t) = vT(1 - e^(-kt)).
  • Understanding of first-order linear differential equations
  • Familiarity with integration techniques, including integration factors
  • Knowledge of terminal velocity concepts in physics
  • Basic calculus skills, particularly in solving DEs
  • Study the method of integrating factors for solving linear differential equations
  • Learn about terminal velocity and its implications in physics
  • Explore the concept of homogeneous and particular solutions in DEs
  • Practice graphing exponential decay functions related to velocity
Students studying calculus, particularly those focusing on differential equations, physics students analyzing motion through fluids, and educators looking for examples of applying DEs in real-world scenarios.
Emethyst
Note that this is a first year, Calculus 12 DE question:
The velocity,v, of an object falling through the Earth's atmosphere obeys the DE dv/dt=g-kv, where k is the called the drag constant and g is the gravitational constant. This equation states that the acceleration of the object is g reduced by an amount that represents air resistance (kv). Air resistance is proportional to the velocity of the object.
a) Find the function v(t) assuming that v(0)=0.
All first year calculus methods used to find DE's.
I just seem to be lost on how to convert the derivative given into an equation that contains the variables given by dv/dt. I have no problems finding antiderivatives, it just seems to be the introduction of variables instead of numbers here that is throwing me off. If anyone can point me along in the right direction it would be greatly appreciated, thanks in advance.
Well if you take kv on the other side than you could see that it is a linear diff equation
That's what I originally tried to do, but I am not sure if I can then integrate both sides, as from what I did:
dv/dt + kv = g
dv + (dt)(kv) = (g)(dt)
I don't know if I am going wrong somewhere here, as I thought for this to be integrated I would have to get it into the form (kv)(dv) = (g)(dt), and from what I did it doesn't look like it will get into that form easily :-p
You need to look at this as two separate equations:
1) v' + kv = 0 (the homogeneous linear DE)
2) v' + kv = g (the nonhomogeneous linear DE)
Can you find the set of solutions vh for the first equation? Hint: There will be a bunch of them, and they are multiples of the same exponential function.
Now can you find a particular solution vp to the second equation?
Your general solution vg will be vh + vp.
Be sure to use your initial condition, v(0) = 0.
Havent you been taught to solve linear diff equation with the help of integration factor?
There is another way of doing this, however depending on whether you're a maths or physics student this may or may not be allowed. So I would ask you to check up on this method with your professor since this method is usually frowned upon by mathematicians. Physicists however use it all the time.
Divide by g-kv on both sides and multiple both sides with dt gives
\frac{dv}{g-kv}=dt
This is easily integrated, don't forget the constant!
\frac{dv}{g-kv}=dt
This is a better, and simpler approach than the one I suggested. I was thinking that the equation was separable, but for some reason this very simple step didn't come to me.
Thanks for all of that help, I managed to find the equation, but now I'm having problems with b) of this question, which states: Let vT=g/k. When v=vT, the acceleration, dv/dt, is zero and thus the object maintains a constant terminal velocity. Rewrite v(t) in terms of vT, and sketch the graph of v(t).
Graphing is no problem for me, I am just not sure how to find the new equation in terms of vT. So far I have the equation written as v(t)=vT(1-e^-kt), but don't know how to continue on with the question. Any help pointing me in the right direction here would be greatly appreciated, thanks.
You've done what they asked of you, rewritten the equation in terms of v_T.
10K
11K
