Yepp, that's what wikipedia says. However do you have any ideas how to find specific line or lines that cause segmentation fault in an application. I tried gdb for "normal" aps, and everything works perfectly, but I can't debug any applications with segmentation faults.
For example:
adrian@ubuntu:~/files/asm$ gdb env_show --quiet
(no debugging symbols found)
Using host libthread_db library "/lib/tls/i686/cmov/libthread_db.so.1".
(gdb) r
Starting program: /home/adrian/files/asm/env_show
Program terminated with signal SIGSEGV, Segmentation fault.
The program no longer exists.
You can't do that without a process to debug.
(gdb) info registers
The program has no registers now.
(gdb) bt
No stack.
(gdb)
and so on, I'm not very experienced with gdb,
--Thanks,
