Deceleration of a falling load of a rope
This discussion focuses on calculating the force experienced by an object falling due to gravity and caught by a rope. The key equations involved include F = ma, v² = u² + 2ax, and the relationship between stress (σ), force (F), and cross-sectional area (A). The participants emphasize that the force exerted by the rope is not constant and that work-energy principles may be more applicable for determining the average force required to stop the falling mass. Additionally, Young's modulus (E = 200 GPa) is highlighted as a critical factor in calculating the strain on the rope.
  • Understanding of Newton's second law (F = ma)
  • Familiarity with kinematic equations (v² = u² + 2ax)
  • Knowledge of Young's modulus and its application in material science
  • Basic principles of work-energy in physics
  • Research the application of work-energy principles in dynamic systems
  • Learn how to calculate stress and strain in materials using Young's modulus
  • Explore the relationship between force, mass, and acceleration in non-constant acceleration scenarios
  • Study the behavior of materials under load, particularly elastic and plastic deformation
Physics students, engineers, and anyone involved in mechanics or material science who seeks to understand the dynamics of falling objects and the forces involved in stopping them.
tommy060289
Hey everyone
Im trying to calculate the force encountered by an object falling due to gravity that is caught by a rope.
Obviously F=ma and since mass is constant I need to find the rate of deceleration. I've tried to using the equation v^2 = u^2 +2ax as v = 0 and u =1.57 m/s so I need to find x to calculate the deceleration.
In order to calculate s I was going to use the equation for young's modulus which is σ/ε and calculate the strain, As E = 200 GPa and I just need to find the stress on the rope, but here in lies my problem, as I can not figure out how to do this. I know the CSA as r = 0.003 m but I don't know what to use for my force value as surely the force is what I am trying to work out in the first place, and I don't think using mass * gravity is sufficient as the force must be greater as we have a velocity
F = m*a
v^2 = u^2 + 2ax
x = l*σ/E
σ =F/A
My attempt is described above but I just can't figure out what to use for F
tommy060289 said:
Hey everyone
F = m*a
v^2 = u^2 + 2ax
x = l*σ/E
σ =F/A
That equation you have quoted applies to constant acceleration.
imagine that instead of a rope, you had a spring. As the spring stretches under the load, the force gets stronger and stronger, meaning higher and higher acceleration, so a formula for a constant acceleration situation is hardly appropriate.
The formula could be used to find the average force - the constant force that would achieve the same event [stopping the falling mass].
You could just as easily use work energy considerations however.
Gravity has done work accelerating the mass as it falls, then the rope does work stopping the falling mass.
If the object fell 3 m, then its weight force times 3m is the amount of work done gaining energy [3mg].
If the object then stopped in 3 cm, clearly the force would have to be 100 times the weight force to do the same amount of work. That force however would not be constant, so 100mg is only the average force [100mg x 0.03 = 3mg; total work the same].
But I'm still struggling going about calculating the distance in which the object is stopped. Is there anyway to calculate this. I could use young's modulus but again, the problem lies in calculating the stress?
Even a steel rope behaves just as really strong spring - provided you do not strain it beyond its yield point. so make use of E = 0.5kx2 and relate k back to the Young's modulus
You are not going to get a number answer, unless you know the mass, how far it fell and young's modulus of the catching rope/wire, and how thick and long it was to begin with.
Of course you could just use M for mass, h for how far it fell, g for gravity, γ for Young's modulus, etc. and derive an algebraic solution.
thanks peter, ill try that!
  • · Replies 38 ·
