Decoherence and the Dust Particle
74 replies · 10K views
Feeble Wonk
The concept of environmental decoherence has been a perpetual thorn in my brain despite an embarrassing amount of time contemplating the idea. At this point, I'm not even sure if I understand what it is purported to resolve. In many ways, it seems to me to be primarily a theory about logical set limitations rather than a mechanism by which a particular quantum state is determined. Sadly, my mathematical inadequacies continue to pose an obstruction to discussing this in terms that you physicists are comfortable with. So, I'd like to try this via an example of decoherence that I've seen cited multiple times in the past.
The precise location of a cosmic dust particle in space is said to be determined, through decoherence, by interacting with just a few photons. First, I'd like to clarify a couple of points that I'm curious about. In what sort of time frame do the involved photon interactions need to occur to achieve decoherence induced localization?
It purports to answer the question "Why do we not encounter macroscopic superpositions such as the neither dead nor alive cat of Schrödinger's thought experiment?" and the answer is "They decay so quickly that we don't have a chance to observe them".
Something on the order of ##10^{-6}## seconds - that order of magnitude estimate comes from Brian Greene, and no matter what you think of his pop-sci stuff he does know how to do the calculations. That is a very extreme case, as interstellar space is about as empty as empty can be. The same dust particle in room-temperature air will decohere maybe ##10^{30}## times more quickly.
They do not need to occur within some timeframe. A single photon can be sufficient for decoherence, so the timeframe of decoherence is given by the density of photons around the dust particle.
I'm sorry. I didn't make my question clear. IF the dust particle localization requires the cumulative interaction with multiple photons, then does it matter if a significant time period elapses BETWEEN these interactions. If a single interaction is sufficient, as mfb suggested, then this question isn't pertinent.
A "measurement" with a single particle (or only a few particles) is not irreversible. An important property of decoherence due to interaction with many particles is irreversibility.
Those many particles are in the dust particle, if the interaction with light is sufficiently incoherent (e. g. visible light or UV light hitting it and exciting some molecule).
But, wouldn't the excitation of a single photon be largely limited to a very small percentage of the total dust particle mass? Would that make a difference in the "degree of irreversibility" of localization?
It's similar with me.
My problems are related to statement of the problem. What we should expect if decoherence does not happens? As I see the only way how we can find out when decoherence has not yet happened is by observing interference (say in double-slit setup).
Another uneasiness with the statement of the problem is that coherence is meaningfully defined for ensemble of particles and not for single particle. And yet I find explanations describing single dust particle.
This leads into my next question, which relates to my feeling that the theory is more about logical set limitation than being a mechanism of state reduction.
If, for the sake of discussion, multiple photon interactions are required to localize a cosmic dust particle in a region of otherwise vacuous space, doesn't the uncertainty regarding the potential paths of the involved photons come into play somehow? I realize that this might sound like a trivial (or even ridiculous) concern, but it speaks to the wholistic ensemble nature of theory. To me anyway, it seems like the theory is simply saying that IF the quantum state is such that a photon's path passes through this point in space, AND IF another photon passes through almost exactly the same space at approximately the same time, AND IF yet another photon from a different direction also passes through that same spot, then that point in the relative space time is localized (essentially by triangulation). And IF, further, the quantum state is such that a dust particle is at that point of convergence, then the quantum state must be reduced to those potential states that reflect that dust particle's position accordingly.
It doesn't feel as if the decoherence "caused" the localization. It seems more like a logistical limitation of the quantum state ensemble set that would be possible IF that set of circumstances were manifest.
That is the point. And the excitation depends on the detailed state of the dust particle. Different states react differently to the photon.
You need to understand the role of Hamiltonians in QM. The Hamiltonian has position parameters, the quantum objects do not have actual positions prior to decoherence (it emerges from that process), hence 'And IF, further, the quantum state is such that a dust particle is at that point of convergence' makes no sense.
Thanks
Bill
Thanks
Bill
Apologies. My post was clumsily phrased. I'm hoping that you might be able to help me through this.
When you say that "quantum objects do not have actual positions prior to decoherence", do you mean that the dust particle in question has a "less than definite" location in the region of space-time vacuum that we are considering? Or, are saying that the region of space-time has no "locational" information at all, prior to decoherence?
I suppose it might be helpful if I tried to explain my (undoubtedly flawed) mental image of the process. I'm picturing a region of space-time in which the "historical" quantum state has already determined the existence of our dust particle via some previous physical event/interaction. However, the "precise" location of the dust particle is undetermined. It's this mental image that motivated my earlier question about the significance of time relative to the sequence of localizing interactions.
Feeble Wonk said:
do you mean that the dust particle in question has a "less than definite" location in the region of space-time vacuum that we are considering?.
I am saying, as I have said many many times in my posts, the QM formalism is silent on such things.
Thanks
Bill
Sorry Bill. I know this sort of discussion is distasteful for you. I'm aware of your ignorance ensemble inclinations, and I'm aware that the formalism is silent as to what is "really" going on during the measurement/observation/interaction event.
Also, while the mathematics is sadly beyond my understanding, I fully concede that the process of state decoherence limits potential quantum states in ways that prevent classical superposition from being observed. What I'm not clear on is why decoherence is thought to be the "mechanism of state reduction", triggering the manifestation of a proper mixture from an improper mixture (assuming that proper mixtures can actually be thought of as having independent existence). And, as is always a challenge, I'm trying to understand this concept in terms of what it implies about the nature of physical existence on an ontological level. I'm aware that that bleeds into a philosophical discussion, but I'm trying to tread carefully in an effort to avoid that.
There's no particular reason why you should be clear on that.
Decoherence tells us why quantum mechanics, as a theory about measurement results, correctly predicts that we do not observe macroscopic superpositions. It's a bigger leap than many are willing to take to accept it as the "mechanism of state reduction".
Feeble. Decoherence is not mechanism of state reduction.. they are separate.. but we tend to joint them together because they occur together. Isn't this your understanding too? My thoughts are correct.. ain't it? Try asking atyy too because he is the highest authority on decoherence...
There are many outstanding authorities on PF, which is why I come here for answers, though I all too often struggle to understand those answers. But yes, I would definitely highly value atyy's input on virtually any subject.
The way I envision it, the decoherence essentially defines what the reduced quantum state "might" be... or at least, what it CAN'T be. So, I guess that would explain why they "occur together", as you said. But, my understanding of the phenomenon is severely limited due to my mathematical inadequacies.
I am still very curious about the questions I've asked above. Sadly, I realize that it's difficult for the PF physicists to give me the answers I'm looking for because I need the explanation to use actual language rather than formulas, and I'm afraid that this concept is one of those that doesn't translate easily into words.
I already spent years trying to understand it including the math. Improper mixture to proper mixture is either collapse or many worlds or bohemian trajectories. So what is your specific question.. so I'd know what are the basic questions asked by laymen (or advanced laymen). What specifically are your questions. Pls. enumerate. I should be able to answer them. If I can't. I'll ask them and know the answer myself.
By "mechanism of state reduction" does it include decoherence causing mixed states to have each branch as separate worlds or does "mechanism of state reduction" simply meant collapse? What is the standard usage of it? Anyone?
I'm interested in your question what is its ontological sense... and relating to thinking what you were saying about dust particle localization.
From my perspective, the "mechanism of state reduction" might result in either... MW branching or Copenhagen collapse... depending on your interpretational preference. It is obviously a less relevant issue in DBB.
I view the "mechanistic" issue to be a question of causation, and I'm aware that this takes the discussion perilously close to philosophy. I suspect that most physicists would consider the general concept (mechanism of state reduction) to be entirely interpretation dependent, which is why many prefer the "shut up and calculate" approach.
None the less, it seems to me that there is an important logical distinction between the mechanism (whatever it is) and decoherence. I can see where decoherence can be thought of as writing the map that state evolution must follow, but I don't see how it can be considered the "driver" of the vehicle (so to speak).
This is another issue that I suspect is entirely interpretation dependent. But, at least to me, it seems like a reasonable question. My presumption, I'll admit, is that the mathematical formalism is describing an ontologically extant entity of SOME kind. But I'm confused by how the quantum states allowed (by decoherence)seem to shift as the scale of the system being considered increases. This concern appears to be particularly severe when you consider the "system" to be the entire space-time universe. It is absolutely possible (if not likely) that I have completely misunderstood this relationship between system scale and allowed quantum states. If so, please correct me.
I hope this makes enough sense for you to respond.
None the less, it seems to me that there is an important logical distinction between the mechanism (whatever it is) and decoherence. I can see where decoherence can be thought of as writing the map that state evolution must follow, but I don't see how it can be considered the "driver" of the vehicle (so to speak).This is another issue that I suspect is entirely interpretation dependent. But, at least to me, it seems like a reasonable question. My presumption, I'll admit, is that the mathematical formalism is describing an ontologically extant entity of SOME kind. But I'm confused by how the quantum states allowed (by decoherence)seem to shift as the scale of the system being considered increases. This concern appears to be particularly severe when you consider the "system" to be the entire space-time universe. It is absolutely possible (if not likely) that I have completely misunderstood this relationship between system scale and allowed quantum states. If so, please correct me.
This part is interesting and I'm still trying to visualize it for a day. If you have references about other physicists attempt to present it.. pls. do so it's clearer.
I have thought all this for 10 years already. Wish I took a 4 year physics degree during those times. But thinking how I may still be confused 10 years later.. maybe I should really get a physics degree.. hmm..Thanks.
If you can't find any references about what you were describing. Please rephrase your questions in the language of pure state, mixed state, entangled composite system, born rule, improper mixture, proper mixture and reduced density matrix. I learned about Decoherence from Hobba so I can't seem to understand what you were saying even when I read the thread over and over. I really need to know what you were thinking.
Let me think about that, and repost. Thanks for the effort.
First consider pure decoherence without born rule applied. I was thinking whether you were mixing the two or referring to which of them. So please give example of the dust particle that encounter decoherence with photons yet without born rule applied (no state reduction).
Sorry for the delay. Life is a little hectic at present, and is likely to be for another few days.
I like your ideas on how to help me pursue this concept. Unfortunately, it points out another of my failings in this matter... which is that I'm not at all confident regarding my understanding of what the various designations of mixtures actually refer to over the evolution of the quantum state.
The mixed state of THIS system would include the set of POTENTIAL locations of the dust particle in question. Is that accurate?
Isn't it that in Many worlds, the POTENTIAL are actually branches or worlds. Anyway what is that you do. I know you are interested in all this because wanting to know if there is any connection to mind. Even physicists like Penrose are contemplating on it like thinking the Planck scale is the origin of qualia. But I know we need utmost scientific and testable theory. After 10 yrs of researching QM. What is the best theory you have read about mind and QM that is connected to decoherence.. just point to web sites lest the moderator gets mad. Remember that it's back to the days of Wigner and Von Neumann when it's been linked.. but after that no more.
Well, yes. But, wouldn't the same information be contained in the CI wave function?
This question is a extremely logical & mathematical formulation is very challenging as long as causation and correlation issues are not resolved yet in this . Anyway, I don't know how challenging it will be if we want to determine more complex event in outer space that involves large number of particles and how would that be if the particles are collocated or separated " multipoint to multipoint" . would that be easier?
Only if you perform a measurement that leads to decoherence.
