Decompose matrix into outer product of vectors
The discussion focuses on techniques for decomposing a 3D matrix into an outer product of vectors, specifically seeking vectors a_i, b_i, and c_i such that M_{i,j,k} = a_{i}b_{i}c_{i}. It is noted that a rank of one is necessary for such decomposition, but the uniqueness of the decomposition is questioned, especially for matrices of higher rank. The conversation explores the relationships between the elements of the vectors and how they can be expressed in terms of ratios, leading to a factorable form. Additionally, it is highlighted that while the outer product yields a rank one matrix, not all rank one matrices can be decomposed in the desired manner. The potential application of Singular Value Decomposition (SVD) for approximating matrices through outer products is also mentioned, though its relevance to 3D arrays remains uncertain.
Pacopag
Hi. I'm wondering if anyone can point me to any information on techniques to decompose a matrix (actually a 3D matrix) into an outer product of vectors. Particularly, given M_{i,j,k}, I want to find vectors a_{i}, b_{i} and c_{i} such that
<br /> M_{i,j,k} = a_{i}b_{i}c_{i}<br />
where the multiplication on the right is an outer product.
I've read that this is only possible if the matrix M has a rank of one, but I can find anything on how to actually decompose the matrix, only that it CAN BE done. Also, if M has rank one, does that mean that there is a "unique" decomposition? What if the rank is something other than one? In that case would it be possible to find a family of solutions?
Thanks for any help.
Edit: strike all this, you meant a different outer product. Lemme think on this a bit more.
Consider the matrix a_ib_j. This matrix is rank 1 since only one row and one column of this matrix is independently determined. The others rows(columns) bear constant ratios to this one row(column). Now if you take the ratio of successive elements in each row, it is easy to calculate a_1/a_2,b_2/b_3\ldots etc.
Now write these ratios in terms of say a_1 and b_1. We name the ratios with the letter k, e.g., a_2=k^a_2a_1 (superscript does not denote exponent). Once you substitute all the k^as and the k^bs, you get a matrix where a_1b_1 can be factored out and its value is known.
At this point, we cannot determine a_1 and b_1 individually. You can select a_1=p and b_1=a_1b_1/p and the resulting vector pairs will all work.
With a little extra work, this approach can be extended to higher order matrices.
That's great Bavid! Is there ANYTHING that can be done if the matrix is not of rank 1? Or is it the case that no such decomposition exists, even up to undetermined coefficients, if the rank is anything other than 1?
It appears to me that rank 1 is necessary but not sufficient for a matrix to be represented as a_ib_j. For example, rank one matrices may have rows differing by a constant, as in (row_i)=m*(row_j)+c which could be rank 1 but not decomposable to a_ib_j.
Vector outer product ALWAYS produces a rank 1 matrix, at least among 3*3 matrices..think about it, there are 6 independent components in the constituent vectors but 9 components in the resulting matrix. So there is a well-defined interdependence of the matrix components. You cannot hope for any random matrix to be expressed as an outer product.
That's great. Thanks.
One way to look at the Singular Value Decomposition (SVD) of a matrix is that it tells you how to express the matrix as a linear combination of outer products of vectors. Thus it may suggest away to approximate a matrix by using only some of the outer products in the linear combination.
I don't know what the SVD tells us about 3D arrays. We'd have to think about that.
  • · Replies 33 ·
