Decrease in pressure due to adiabatic expansion derivation?
The forum discussion focuses on deriving the relationship \(\frac{dp}{p} = \frac{\gamma}{\gamma-1}\frac{dT}{T}\) for adiabatic expansion. Key equations referenced include the Poisson equations \(Pv^{\gamma}\) and \(Tv^{\gamma - 1}\), alongside the Ideal Gas Law \(Pv = R_{d}T\). Participants discuss the relationship between specific heat capacities, where \(\gamma = \frac{C_p}{C_v}\) and \(R = C_p - C_v\). The derivation involves using differentials and approximations to connect changes in pressure and temperature.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with the Ideal Gas Law
  • Knowledge of calculus, specifically differentials and logarithmic functions
  • Concept of specific heat capacities, \(C_p\) and \(C_v\)
  • Study the derivation of the Poisson equations in thermodynamics
  • Learn about the application of differentials in thermodynamic equations
  • Explore the implications of the Ideal Gas Law in real-world scenarios
  • Investigate the significance of specific heat ratios in various gases
Students and professionals in thermodynamics, physics, and engineering fields, particularly those focused on fluid dynamics and heat transfer.
monnapomona
Show that \frac{dp}{p} =\frac{\gamma}{\gamma-1}\frac{dT}{T} if the decrease in pressure is due to an adiabatic expansion.
Poisson equations:
Pv^{\gamma}
Tv^{\gamma - 1}
Ideal Gas Law:
Pv=R_{d}T, where R_{d} is the dry air gas constant.
Hydrostatic Equation:
\frac{dp}{dz} = - ρg
I tried making those two equations equal to each other since they are equivalent (i think) and differentiating on both sides but i ended up with \frac{\gamma - 1}{\gamma} in the final result...
EDIT: I was looking up adiabatic atmosphere and found this. I'm wondering where the formula p^{\gamma - 1}T^{\gamma} = constant comes from...
Poisson equations:
Pv^{\gamma} =??
Tv^{\gamma - 1}=??
Ideal Gas Law:
How is γ related to Cp and Cv?
You can consider air as ideal gas. Use the Ideal Gas Law to eliminate V. ehild
ehild
I think \gamma = Cp/Cv and R = Cp - Cv.
I used an entropy equation and made it equal to 0:
0 = Cp*ln(T2/T1) - R*ln(p2/p1) and got (R/Cp)*ln(p2/p1) = ln(T2/T1). So I solved for R/Cv = \gamma -1 / \gamma... and the final result was
(P2/P1)^((\gamma -1) / \gamma) = T2/T1
Am I on the right track with this?
You are on the right track, but write the equation with the differentials.
ehild
ehild
This is where I'm stuck... could i say P2/P1 = P and T2/T1 = T, then take the ln of the equation to bring the exponent down?
Assume that P1=Po and T1=To are fixed, and P2=Po+dP, T2=To+dT, dT and dP very small. How are dP and dT related? Have you studied differentials? ehild
ehild
Is dt and dp directly proportional?
And I have calculus background from a few years ago so I'm a bit rusty on some concepts... like differentials.
Try to refresh your Calculus knowledge.
You have the equation (P2/P1)^((γ -1) / γ) = T2/T1.
Write P2/P1=(Po+dP)/Po=1+dP/Po and T2/T1=1+dT/To. dP/Po << and dT/To <<1. The original equation becomes
(1+dP/Po)(γ-1)/γ=1+dT/To.
Use the approximation (1+δ)n ≈1+nδ,valid for δ<<1.
You can check it, what is (1+0.001)3, for example?
What do you get?
ehild
What do you get?
ehild
You would get 1.003003 so its approximately 1. Curious question, why does this approximation matter to the proof or derivation of the original question?
You get the desired formula with that approximation.
ehild
  • · Replies 32 ·
