Deduction of centripetal force
16 replies · 7K views · last reply
Misr
I have questions about the deduction of law of centripetal force
http://img42.imageshack.us/img42/5841/centripetalforce.gif
Why do we assume that the change in direction of velocity of the object is V(t+dt)
And similarly the change in direction of radius?
Also what is the triangle of velocity ? and how to draw it?
http://img203.imageshack.us/img203/4669/triangleofvelocity2.gif
Do we use only the magnitude of these directions to express the sides triangle of velocity bec. The triangle sides can't be negative while the directions could be +ve or negative?
Thanks
The velocity (for uniform circular motion) is always tangent to the circle. V(t+dt) is the velocity at time t+dt, not the change in velocity. The change in velocity is V(t+dt) - V(t).
You already have a drawing of the triangle of velocity. It represents the vector addition: V(t+dt) = V(t) + ΔV. The "trick" is realizing that the angle between the two velocity vectors is θ.
When drawing a vector, the length of the arrow represents the magnitude, which is always positive. The direction of the vector is represented by the direction of the arrow.
Read this derivation: http://hyperphysics.phy-astr.gsu.edu/HBASE/cf.html#cf2"
Thanks this really helped me but actually i can't understand this point
I have another question
can we prove that the triangle of velocity in the second circle is similar to the triangular cab (ABC) in the first circle?
Thanks again
Two points:
(1) The angle between the two velocity vectors is θ. To understand that, realize that the velocity vector is always perpendicular to the radius. Thus when the radius moves by an angle θ, so must the velocity vector.
(2) The triangles are similar. In the first circle you have an isosceles triangle with angle θ formed by the radii; In the second circle you have an isosceles triangle with angle θ formed by the velocity vectors. Two isosceles triangles with the same angle are similar.
Another point: For a small change in angle dθ, the length AB (in the first diagram) will equal rdθ.
Two points:
mmm actually i can't imagine can u draw an illustration?
i'll put a proof later to make sure
Thanks so much
bec ΔV = V(t+dt) - V(t)
therefore V(t+dt) = V(t) + ΔV ?Right?
The velocity vector is always a fixed angle (90°) with respect to the radius. If the radius points in the +x direction, the velocity vector points in the +y direction. When the radius has moved to be 30° (for example) above the x-axis, where must the velocity vector point?
Right.
Thanks so much
I want to ask if this works ?
http://img215.imageshack.us/img215/3401/proof3f.jpg
http://img693.imageshack.us/img693/8039/proofe.jpg
http://img705.imageshack.us/img705/5425/proof2t.jpg
I'm very sorry 4 the handwriting but I'm in a hurry
Thanks again
Also i made an animated picture to demonstrate ur words
http://img30.imageshack.us/img30/1725/centripetalanimated.gif
Is my understanding right?
I want to make sure if my two posts are right
Good
I think i got it now
but i have another way and also i want to make sure if its right ?
[url]http://img24.imageshack.us/i/prooffz.jpg/[/url]
IS this right
Thanks so much
I'm very sorry its my fault I should have explained more
Actually I don't really need to put this proof but I'm just eager to know if its right or wrong
http://img246.imageshack.us/img246/745/centripetalforce2.jpg
This pink line is an extension to the velocity vector
And I drew a green radius to help me in the proof
I don't want to prove any thing new I just want to prove that the angle between the velocity vectors is equal to the angle between the two radii .
I understand what u said but I want to make sure if this method also works .
Since the velocity vector is at point b is parallel to ax
Therefore m(<MXY)=m(MXA)=m(<b) = 90 degrees
Therefore XA = XY (According to a theorem in geometry )
And MX is a common side in the two trianles MXY and MXA
Therefore triangle MXY is congruent to triangle MXA
Therefore m(<2)=m(<3)
Since m(<1) = 1/2 m(<AMY) (angle of tangency and centeral angle subtended by the same arc)
Therefore m(<1) = m(<2)
I hope its obvious now
Thanks
Looks good to me. You can also say that m(<1) = m(<2) since they are both complementary to angle MAX.
Yeah this way is better and much more easier
this is a very interesting discussion
nothing is well-illustrated in my txt book
thanks so so much this really helped
As an aside, there's a much easier derivation of this.
[tex]\vec v \cdot \vec r =C[/tex]
Derive both sides:
[tex]\vec a \cdot \vec r + \vec v \cdot \vec v =0[/tex]
Get rid of the vectors:
[tex]-ar + v^2 = 0[/tex]
Nice. Combine that with a similar treatment of [itex]\vec v \times \vec r = C[/itex] to show that the acceleration is radial.
