Define Speed in Rotating Machines: Answer & SI Units
  • Thread starter Thread starter Solidsam
    Speed Term
Speed in rotating machines refers to the rate at which an object rotates, commonly measured as angular velocity, with the SI unit being radians per second (rad/s). Torque-speed matching is crucial in motor-driven machine design because it ensures that the motor can provide sufficient torque at various speeds for optimal performance. For a fan load, the torque-speed curve typically shows a decrease in torque as speed increases, while for a high static friction load, the curve indicates higher torque requirements at lower speeds. Understanding these characteristics helps in selecting the appropriate motor for specific applications. Proper torque-speed matching enhances efficiency and prevents motor overload.
Solidsam
electronics question
Define the term “Speed” as employed in rotating machines, and state its (S.I)
units.
anyone know the answer? is it rad per second?
I suspect it's angular velocity, which indeed has the unit rad/s.
Explain why “Torque-Speed” matching is important in designing motor-driven
machines. Illustrate your answer with torque-speed plots characteristic of:
i) A fan load
ii) A high static friction load
?!?1?111one
  • · Replies 101 ·
12K
  • · Replies 56 ·
  • · Replies 27 ·
