Definite Integrals with inverse of function
The problem involves finding the integral of the inverse function f^-1(x) from 5 to 9, given that f(x) is continuous and decreasing on the interval [5, 13]. The integral of f(x) from 5 to 13 is provided as 70.64758. A suggested approach is to use the substitution u = f(x) and apply the formula that relates the integral of a function and its inverse: ∫ f^-1(y) dy = bβ - aα - ∫ f(x) dx. This method relies on the properties of monotonic functions and their inverses. The discussion emphasizes visualizing the relationship through graphing to understand the areas involved in the integration.
eprparadox
Suppose f(x) is continuous and decreasing on the closed interval 5 <= x < 13, that f(5) = 9, f(13) = 5 and that the
integral of f(x) from 5 to 13 is 70.64758.
Then the integral of f^-1(x) from 5 to 9 is equal to what?
(Note: f^-1(x) is the inverse of f(x))
I really don't know how to solve this problem. I know that f^-1(f(x)) = x. Any ideas would be great. Thanks.
You want to find \int_{u=5}^9 f^{-1}(u)\,du
Try the substitution u=f(x)
f is a positive monotone function on [a,b] where 0 < a < b and f has an inverse f^-1. Set \alpha = f(a), \beta = f(b) and then use this formula:\int_{\alpha}^{\beta} f^-1(y) dy = b \beta - a \alpha - \int_a^b f(x) dx.
This formula can be seen by drawing an example graph. Along the x-axis, you are integrating f(x)dx. ALong the y-axis you are integrating f-1(y)dy. Draw some rectangles and add/subtract areas to get the formula.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
