Can Differentiability of a Function be Extended to its Absolute Value?
The discussion focuses on proving that if a function f is differentiable at a point c and f(c) ≠ 0, then the absolute value function |f| is also differentiable at that point. The participants establish that since f is continuous and maintains the same sign around c, the absolute value function can be expressed in terms of f for small perturbations around c. Specifically, if f(c) > 0, then |f(c+h)| = f(c+h) for small h, and if f(c) < 0, then |f(c+h)| = -f(c+h) for small h, allowing for the calculation of the derivative of |f| at c.
  • Understanding of the formal definition of differentiation
  • Knowledge of continuity and its implications in calculus
  • Familiarity with the properties of absolute value functions
  • Basic skills in limit processes and epsilon-delta definitions
  • Study the formal definition of differentiability in calculus
  • Learn about the implications of continuity on differentiability
  • Explore the properties of absolute value functions in calculus
  • Investigate the epsilon-delta definition of limits for deeper understanding
Students studying calculus, particularly those focusing on differentiation and continuity, as well as educators seeking to clarify concepts related to absolute value functions and their differentiability.
omri3012
By the formal definition of differentiation Prove that if f differentiable in c and f(c)\neq0 then |f| differentiable in c.
I know that if f differentiable do it also continues but I stuck because this fact correct necessarily only for one direction...
Let c be such that f(c) is not 0. Recall that since f is differentiable, it is continuous.
Suppose first that f(c) >0. Intuitively, the fact that f is continuous implies that as you wobble a little around c, f wobbles a little around f(c), and so for small enough wobbling around c, f should remain of the same sign as f(c). In other words, if our understanding of continuity is correct, we should be able to prove that there exists an \epsilon&gt;0 such that f(x)>0 for all x in (c-\epsilon,c+\epsilon). In particular, this means that |f(c+h)|=f(c+h) for small enough h.
And in the same way, we can show that if f(c)<0, then |f(c+h)|=-f(c+h) for small enough h.
Hopefully, you see how you can use this to calculate the derivative of |f| at c.
Thanks,
That was very helpful :)
  • · Replies 22 ·
